Our oven ignitor was glowing red hot after doing a cold cleaning of our stove. I unplugged, wiped the interior of the oven out - several times over, including carefully cleaning where the ignitor plugs in near the gas line.
I plugged the oven back in and the ignitor sparked, and a wire caught fire. I received the replacement ignitor today, plugged it in. Sparking and smoking started happening near the connectors - and I immediately unplugged the oven.
What could be causing this? I am unsure of what else could be causing this short... Please help - thanks in advance.
Originally Posted by: timwiseman Our oven ignitor was glowing red hot after doing a cold cleaning of our stove. I unplugged, wiped the interior of the oven out - several times over, including carefully cleaning where the ignitor plugs in near the gas line.
What could be causing this? I am unsure of what else could be causing this short... Please help - thanks in advance. Tim, You most likely have water/moisture inside the connector, or the insulation is still moist, and shorting to ground. How bad was the wire that caught fire, damaged ? You may want to take a blow dryer and eliminate as much moisture from the connectors and wiring as possible. Thanks, :) :) :)
