tbdbitljim
#1 Posted : Tuesday, February 24, 2009 11:25:58 AM(UTC)
tbdbitljim
I have a Jenn-Air electric oven and the clock doesn't work so my wife cannot use the time bake on the oven. Is there anything else that could be wrong besided just the clock. How is it repaired.
#2 Posted : Tuesday, February 24, 2009 1:16:06 PM(UTC)
Model D140
Here is a service manual
http://www.servicematters.com/m...s/16000446(ER001-00).pdf
The timer shows Requires Special Attention often means obsolete but it is worth giving them a call.
Usually it is the timer. You could check that all the connections are OK.
How is it repaired.
Replace it
If unavailable there are places that repair mechanical times.
Perhaps someone else will jump in and recommend one.
