sbogdanos
#1 Posted : Tuesday, February 24, 2009 5:39:50 AM(UTC)
sbogdanos
I just purchased a ge jgs968sek3ss gas stove. As I was transporting it the glass cooktop broke.(wb62t10543). Should I get it serviced or is it possible for me to replace it myself?
TechnicianBrian
#2 Posted : Tuesday, February 24, 2009 5:52:37 AM(UTC)
TechnicianBrian
You can do it yourself, but if it was just purchased and damaged while in transit (hopefully in the original box) I would get it serviced. The tops are not inexpensive.
sbogdanos
#3 Posted : Tuesday, February 24, 2009 6:20:18 AM(UTC)
sbogdanos
Hi Technician Brian,
Unfortunately I purchased it used. I did see that the tops are pretty expensive, do you know if I need to buy anything else to replace the top?
TechnicianBrian
#4 Posted : Tuesday, February 24, 2009 7:12:39 AM(UTC)
TechnicianBrian
Thats to bad. Get the top and the gaskets on the side and that should be all you need. Remove a bunch of screws to get the top off, and you will get to know your new range better than most.
