My oven just stopped working a few days ago. It had been acting up for bout a month and the control panel was hard to read. The numbers where really light and we have had a bunch of power surges lately. I tried to read the label on my oven to get the model. It is either WHIRLPOOL RBD275PDB1 or RBD275PDQ1. I cannot read the last three digits of the model really well. But I am a baker at home and I need my oven. I love to cook and my family is really wanting on of my cakes. If anyone has any suggestions pls let me know. I have taken the oven apart and I hooked the volt meter to the fuse that is on the control panel. It is labeled as F1 but I have not found this on the spec sheet that I have to tell me what it is. I cannot find a trouble shooting guide for it. The oven was in the house when we bought it. The fuse is not showing any conductivity put shows electricity . I noticed the filiament in it is damanged tho. ALso it has 4 coil relays that looked to be arked out. I do not know but I can take a pic and put it on here for any help. Thank YOu .
THIS FORUM IS DEAD!!!!!!! |
I got a fuse from my instructor and I am going to try to change the fuse out this afternoon when I get home. I cannot find the fuse in the diagram when it pulls it up from the post. I will let u know wha it does, Thank you
I changed the fuse and my oven began working again but now the control is going weak again. But when it first came back on the codes f2 and f3 showed up. I looked it up and it says its thermal sensor. where will I find these and where are they located. thank you . And mine is the white oven also. Originally Posted by: denman
The sensors are Item 29 in Sections 1 and 2. Here is a good link, check out 7, 8, 20 and 21. http://www.applianceaid.com/elecrange.htmlThe sensors should not cause dimming of the display so odds are that the control board is the problem. |
