Discuss
GE Tru Temp electric oven
 in
This oven, which has always worked perfectly, suddenly developed a heating problem last night. Range and broiler work fine but
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » GE Tru Temp electric oven
  #1 (permalink)
Old 02-23-2009, 08:04 AM
Junior Member
mac4141 is on a distinguished road
Default GE Tru Temp electric oven
Brand: GE   Age: 5 - 10 years
a heating problem last night. Range and broiler work fine but the
oven won't heat up beyond 200 or so, if that. Don't know if this is the heating element, thermostat or what. Any suggestions? THANKS!!!
  #2 (permalink)
Old 02-23-2009, 06:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the range?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-24-2009, 07:14 AM
Junior Member
Default
It's JP26BYSH
  #4 (permalink)
Old 02-24-2009, 02:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The model number you posted does not come up. Is it American model? Verify and repost it.
__________________
  #5 (permalink)
Old 02-24-2009, 02:29 PM
Junior Member
Default
Sorry, sloppy typing. Correct model # is:
JBP26BY5WH
Does that look better?
Thanks!
  #6 (permalink)
Old 02-24-2009, 02:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Thank you. This time it looks much better .
Pull the range out of the wall, remove the rear panel and check the wires to the Bake heating element.
If there is nothing wrong then remove the wires from the Bake heating element and check the element for continuity. Replace the heating element if it's open.
If there is nothing wrong then the problem is a bad control board.
- The part number for the Bake element is AP2031067
- The part number for the control board is AP2632445
Here are the break down diagrams for the GE range Model JBP26BY5
__________________
  #7 (permalink)
Old 02-24-2009, 03:08 PM
Junior Member
Default
MANY thanks! Thanks also for the
diagrams and parts info.
Even more, I appreciate your
time and generosity. I've been unemployed for some time
now. Formerly, I would have thought nothing of calling
a repair man. Now, that's strictly a last-ditch option.
I REALLY appreciate your help. THANK YOU!
  #8 (permalink)
Old 02-24-2009, 04:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #9 (permalink)
Old 03-08-2009, 12:21 PM
Junior Member
Default Further to previous oven issue - new part doesn't fit
Gene -
I tried both the bake element and the control element. The
problem wasn't the bake element so I assume it's the control
element. I ordered that part from the link you sent and while it looks ALMOST identical, the connections in the back are not exactly the same. In particular, I have a connection that sends four red wires to the surface burner controls on the old one but can't find a corresponding place on the new part. Also, the instructions (such as they are) for the new part indicate a "Line Voltage (black)" connection, which is not visibly present on the old part. It also refers to a "Purple Broil Wire". I have a blue wire but not purple!
Some of the conectors on the new panel are differently located form the old one, too, so it isn't clear which is which.
The part I received was TEGA 2083290182. Any thoughts? I really cannot afford a serviceman at this point but gotta have my oven working. THANKS!
Doug
I ordered from the link you sent, which specified
  #10 (permalink)
Old 03-08-2009, 06:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by mac4141 View Post
...1. In particular, I have a connection that sends four red wires to the surface burner controls on the old one but can't find a corresponding place on the new part...
...2. Also, the instructions (such as they are) for the new part indicate a "Line Voltage (black)" connection, which is not visibly present on the old part. It also refers to a "Purple Broil Wire". I have a blue wire but not purple!...
...3. Some of the conectors on the new panel are differently located form the old one, too, so it isn't clear which is which....
Doug,
1. This control board controls only the oven functions and has nothing to do with the surface burners.
2. The black wire on all appliances should be a "Line voltage". The wire to the Broil element could be a different color. You have to trace it from the element.
3. All terminals on the old and new boards should be marked and you have to reconnect them according to these marks.
If you can post the pictures of both control boards, the range wiring diagram and the installation instructions it might help better.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpooel electric oven not reaching set temp Tracy Winkler Oven Repair (including Ranges and Cooktops) 1 02-09-2010 01:55 AM
Electric oven does not hold set temp. John G. Oven Repair (including Ranges and Cooktops) 0 01-22-2010 12:10 PM
gas oven temp does not stay at set temp rwarlock Oven Repair (including Ranges and Cooktops) 0 01-16-2010 07:58 AM
Oven temp varies from display temp topxfuelx69 Oven Repair (including Ranges and Cooktops) 0 10-14-2009 01:45 PM
GE electric stove won't reach displayed temp cynthiar Oven Repair (including Ranges and Cooktops) 1 03-23-2008 01:15 PM
