I just went to replace the bulb in my electric kenmore range. The bulb broke off while I was removing it and sparked inside the oven. After I replaced the bulb I looked at the time/temperature display and it was off, the oven light wasn't working either. I thought that the circuit breaker popped but it didn't. The surface burners work fine, but the oven and display are completely inoperable. I turned off the breaker for a little while thinking that it may reset itself but no luck. Are there any fuses, sensors, or circuit breakers inside the oven? Or do I have to replace the entire display module? Are there any other parts to replace as well.
Thanks for your help in advance,
Anthony
There is no fuse on that oven. It sounds like the clock control board has been shorted out. Tom
