Discuss
Whirlpool Oven Spark Electrode Install
 in
Looking for install instructions from front left spark electrode for this model. Thank you! m
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool Oven Spark Electrode Install
  #1 (permalink)
Old 11-12-2007, 05:34 PM
mattsegawa mattsegawa is offline
Junior Member
mattsegawa is on a distinguished road
Default Whirlpool Oven Spark Electrode Install
Model Number: sf395leeq   Brand: Whirlpool   Age: Less than 1 year
Thank you!
m
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-18-2007, 02:59 PM
Junior Member
Default Help
Any word on this question. Install instructions fro the spark electrode. Thank you
  #3 (permalink)
Old 11-19-2007, 01:45 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the burner cap. Remove the two screws, holding the burner.
If they are rusted in then you have to drill them out and order a new screws.
Lift the burner and remove the igniter from the burner. Cut the wire about 10" from the old igniter (do not let the wire to fall). Cut the wire about 10" from the new igniter and put the wire from the new igniter through the hole in the burner.
Connect both wires, using a ceramic high temperature wire nut.
Assemble the burner in the reverse order.
- The part number for the screw AP3126303
- Here are the break down diagrams for the Whirlpool range Model SF395LEEQ0
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
spark or no spark Tommy T. Oven Repair (including Ranges and Cooktops) 18 11-05-2008 06:26 PM
Help - instructions to install oven igniter lrg51 Oven Repair (including Ranges and Cooktops) 27 07-07-2008 02:14 PM
spark module replacement Mike R. Oven Repair (including Ranges and Cooktops) 0 11-12-2007 02:35 PM
Spark Igniter pgronvall Oven Repair (including Ranges and Cooktops) 0 11-08-2007 06:55 AM
One burner will not spark bulldog217 Oven Repair (including Ranges and Cooktops) 1 09-29-2007 12:06 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
