So on this model the big double burner on the front left. It pops and does not burn completely. I can smell the propane. In taking it apart - every screw was rusted in place some were rusted thru completely the tops just pulled out, others were rusted in place, and broke when I tried to remove them.- i know propapne burning creates water - can't someone tell their engineers that? So I figure the pieces not being held in place are allowing in air and it is screwing up the mix, and being inconsistant. Is that a working hypothesis? and if so - I guess i have to replace the burner AP3965198? Help! Carl Johansson Auberry Ca
