Hello, I have a problem with our accubake wall oven. When my wife was baking the broil element came on and the oven got so hot the oven locked. Tried resetting power but broil element stays on. I believe the control board with the relays are bad or sticking. What do you think? I checked the temperature sensor and it checks 1k ohms at room temperature.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: ztied@cox.net Hello, I have a problem with our accubake wall oven. When my wife was baking the broil element came on and the oven got so hot the oven locked. Tried resetting power but broil element stays on. I believe the control board with the relays are bad or sticking. What do you think? I checked the temperature sensor and it checks 1k ohms at room temperature. It sounds like a control board problem to me. Tom
