Discuss
Electric Double Wall Oven Warm, not Hot
 in
On Thursday, the top oven was working fine, next day it wasn't. (Bottom oven hasn't worked in years,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Electric Double Wall Oven Warm, not Hot
  #1 (permalink)
Old 11-11-2007, 01:55 PM
jcrump55 jcrump55 is offline
Junior Member
jcrump55 is on a distinguished road
Default Electric Double Wall Oven Warm, not Hot
Model Number: rb1300pxk   Brand: Whirlpool   Age: More than 10 years
On Thursday, the top oven was working fine, next day it wasn't. (Bottom oven hasn't worked in years, elements removed) The oven light comes on and the clock works. The indicator light by the temp setting knob does NOT come on.
When it stopped working, the elements get warm to the touch, but never get hot.
I'm guessing it's a voltage problem, that it's only receiving one 120v leg of the 240v. I changed out the circuit breaker with an identical 240v 60A breaker, but the problem remains the same. I'd rather not have to pull the oven out of the wall just to check voltage at the oven. Can I check voltage where the elements plug in? Should it be 240v there? What else can I easily check?
I'm going to have to purchase a voltmeter to test with, any suggestions? "Every task is an excuse to purchase a new tool"
Any other thoughts that I'm over looking?
Thanks,
Jeff
Related Models
Whirlpool RB1300XKW0
Whirlpool RB1300XKW1
Frigidaire RB130FA0 Frg(v5) / Electric Range
Frigidaire RB130FF0 Frg(v4) / Electric Range
Frigidaire RB130FH0 Frg(v6) / Electric Range
Frigidaire RB130FL0 Frg(v3) / Electric Range
Frigidaire RB130FM0 Frg(v2) / Electric Range
Frigidaire RB130FW0 Frg(v1) / Electric Range
Whirlpool RB130PXK0
Whirlpool RB130PXK1
Whirlpool RB130PXK2
Whirlpool RB130PXK3
Whirlpool RB130PXV0
Whirlpool RB130PXV1
Whirlpool RB130PXV3
Whirlpool RB130PXV4
Frigidaire RB131CA0 Frg(v1) / Electric Cooktop
Frigidaire RB131CA1 Frg(v1) / Built - in Electric Cooktop
Frigidaire RB131CF0 Frg(v2) / Electric Cooktop
Frigidaire RB131CF1 Frg(v2) / Built - in Electric Cooktop
Frigidaire RB131CH0 Frg(v3) / Electric Cooktop
Frigidaire RB131CH1 Frg(v3) / Built - in Electric Cooktop
Frigidaire RB131CL0 Frg(v4) / Electric Cooktop
Frigidaire RB131CL1 Frg(v4) / Built - in Electric Cooktop
Frigidaire RB131CM0 Frg(v5) / Electric Cooktop
Frigidaire RB131CM1 Frg(v5) / Built - in Electric Cooktop
Frigidaire RB131CW0 Frg(v6) / Electric Cooktop
Frigidaire RB131CW1 Frg(v6) / Built - in Electric Cooktop
Frigidaire RB131NL1 Frg(v2) / Electric Range
Frigidaire RB131NL2 Frg(v3) / Electric Cooktop Range
Frigidaire RB131NL3 Frg(v6) / Electric Cooktop Range
Frigidaire RB131NM1 Frg(v3) / Electric Range
Frigidaire RB131NM2 Frg(v1) / Electric Cooktop Range
Frigidaire RB131NM3 Frg(v4) / Electric Cooktop Range
Frigidaire RB131NW1 Frg(v1) / Electric Range
Frigidaire RB131NW2 Frg(v2) / Electric Cooktop Range
Frigidaire RB131NW3 Frg(v5) / Electric Cooktop Range
Frigidaire RB136CDB0 Frg(v1) / Electric Range
Frigidaire RB136CL1 Frg(v1) / Electric Cooktop
Frigidaire RB136CL2 Frg(v1) / Electric Cooktop
Magic Chef RB150ALM Ref - Top Mount
Magic Chef RB150ALV Ref - Top Mount
Magic Chef RB150AM Ref - Top Mount
Magic Chef RB150AV Ref - Top Mount
Magic Chef RB150PA Ref - Top Mount
Magic Chef RB150PLA Ref - Top Mount
Magic Chef RB150PLW Ref - Top Mount
Magic Chef RB150PW Ref - Top Mount
Magic Chef RB150RA Ref - Top Mount
Magic Chef RB150RLA Ref - Top Mount
Magic Chef RB150RLW Ref - Top Mount
Magic Chef RB150RW Ref - Top Mount
Magic Chef RB150TA Ref - Top Mount
Magic Chef RB150TLA Ref - Top Mount
Magic Chef RB150TLM Ref - Top Mount
Magic Chef RB150TLV Ref - Top Mount
Magic Chef RB150TLW Ref - Top Mount
Magic Chef RB150TM Ref - Top Mount
Magic Chef RB150TV Ref - Top Mount
Magic Chef RB150TW Ref - Top Mount
Magic Chef RB151ALV Ref - Top Mount
Magic Chef RB151AM Ref - Top Mount
Magic Chef RB151AV Ref - Top Mount
Magic Chef RB151PA Ref - Top Mount
Magic Chef RB151PA-P Ref - Top Mount
Magic Chef RB151PFA Ref - Top Mount
Magic Chef RB151PFW Ref - Top Mount
Magic Chef RB151PFX Ref - Top Mount
Magic Chef RB151PLA Ref - Top Mount
Magic Chef RB151PLA-P Ref - Top Mount
Magic Chef RB151PLFA Ref - Top Mount
Magic Chef RB151PLFW Ref - Top Mount
Magic Chef RB151PLW Ref - Top Mount
Magic Chef RB151PLW-P Ref - Top Mount
Magic Chef RB151PLX Ref - Top Mount
Magic Chef RB151PW Ref - Top Mount
Magic Chef RB151PW-P Ref - Top Mount
  #2 (permalink)
Old 11-11-2007, 05:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Jeff
The first thing I would do is open the control panel and check all wires and connections for burned wires or terminals on the thermostat and/or selector switch.
Inside the control compartment you will find the terminal block (where the incoming wires are connected to the oven circuit).
Unfortunately your oven is so old, I can not find the wiring diagram. It would help if you have the wring diagram and can post it for me.
__________________
  #3 (permalink)
Old 11-12-2007, 08:36 PM
Junior Member
Default
Gene,
Thanks for your reply. I think I lied about the model number; it's a Whirlpool RB130PXK, not RB1300PXK.
I took the control panel off, and don't see any wiring or insulation that looks obviously burned. I do see the wiring block with 2 red, 2 white, and 2 black. I'm almost out of reach, and my cheap voltmeter doesn't have clips, just probes. I'm an electricity wimp, so I think I'm going to avoid checking voltage there. I guess I'll leave it apart and and let the local repair guy make some Christmas money off me.
Again, thanks for your help,
Jeff
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Double Wall oven choldca Oven Repair (including Ranges and Cooktops) 6 10-13-2009 03:43 PM
GE Electric Double Wall Oven won't bake or broil tjp Oven Repair (including Ranges and Cooktops) 1 01-21-2009 08:15 AM
Kenmore double oven, Electric Freddyk Oven Repair (including Ranges and Cooktops) 1 11-21-2007 08:14 PM
Electric Double Oven - Lower Locked lfein Oven Repair (including Ranges and Cooktops) 0 09-21-2007 03:24 PM
whirlpool electric wall oven problem devdry Oven Repair (including Ranges and Cooktops) 1 09-15-2007 11:30 PM
