Originally Posted by: moncho11 after a power surge my range oven does not work. i think is giving an f5 code and i follow the instructions on the schematic and nothing. pls help Moncho, The F5 code indicates, several possibilities, especially after a power surge. damaged clock, burnt damaged wires or switches. A couple of things to try, first Program a self clean cycle, if it will, let the cycle run for a few minutes, then cancel the cycle, hopefully we have a switch that is neither open or closed and the reset may work. Turn the power off to the range for 5 to 10 minutes. Turn the power back on and then program a bake cycle and see if the F5 code comes back. If that doesn't solve the problem, you'll need to remove the range from the counter, remove the back panels and check for damaged wires and switches on the self clean latch/switch assembly, the door light switch, and check that the actuator rod on the self clean latch is in position on the motor assembly.Good Luck, :) :) :)
