I used oven tonight at 350 degrees for about one and one half hours. I turned the oven off (I thought) and in about 20 minutes an alarm type buzzer sounded and I checked the oven. On the display panel there was an F3E2 code. I turned the electrical power to the oven off but could continue to hear the gas still burning (propane) and the oven was continuing to heat. :eek: After about 15 minutes and the warning buzzer and code coming back on several times, it finally shut off. Can you tell me what my problem is....a thermostat of some kind? Is this something I can repair myself or do I need a "real" repairman. Thanks for your reply! :)
