Replaced melted down bake element...now the oven heats but does not shut off...no error codes...shorted element when installing new one... probably the control panel? When I set the temperature...it does seem to measure it properly at least until it gets to the set temperature. Any input?
Did I read correctly that you shorted the element when installing the new one? If so, you are probably correct that the control board ( AP4100737) now has the bake relay contacts fused together resulting in the element staying on.
