Are there any diagrams/pictures/videos to show how to replace the hinges on the oven door on the Amana ACS7270AS? I have purchased the hinges from appliancepartspros because the oven door does not shut completely, hence the heat escapes from the top of the door and front panel gets very hot when oven is in use. This is a friend's oven and before I attempt to replace the parts, I would like to know how its done so that I do not spend hours taking the whole thing apart ! :o
