2 Pages12>
Tom H
#1 Posted : Monday, February 16, 2009 7:37:45 AM(UTC)
Tom H
Have a 14 year old Jenn-air oven. The electronic control panel does not work (can still use the oven however). Aside from buying a new control panel, is there anything else that might have caused the panel to go out?
#2 Posted : Monday, February 16, 2009 5:21:43 PM(UTC)
Tom,
When you said "control panel does not work" did you mean the membrane panel does not respond or the electronic oven control dimmed?
Tom H
#3 Posted : Tuesday, February 17, 2009 1:25:10 PM(UTC)
Tom H
Gene, There is no lights on the control panel screen. For example, when you hit BAKE and add 350 degrees, the numbers do not show up. The panel is black. The oven, however, will heat to 350.
Tom
#4 Posted : Wednesday, February 18, 2009 12:02:59 PM(UTC)
Tom,
The problem you described calls "Dim display". Correction in most cases is to replace the Electronic Oven Control (#3 on the diagram).
- The part number for the EOC is AP4088560
Tom H
#5 Posted : Wednesday, February 25, 2009 1:40:31 PM(UTC)
Tom H
I have successfully replaced the oven control panel. The cleaning cycle went fine, but afterwards I have tried to use the oven and am now having a different problem. The oven will not heat. I program Bake at 350 and the panel goes to Pre-heat at 100 degrees. But it does not heat, nothing, nada. I checked to make sure the child protection lock was off after the cleaning cycle. Any ideas??????
#6 Posted : Wednesday, February 25, 2009 2:59:43 PM(UTC)
Tom,
Open the control panel and check the high limit switch (#4 on the diagram) for continuity. Replace if it's open.
Tom H
#7 Posted : Thursday, February 26, 2009 11:37:25 AM(UTC)
Tom H
Thank you. I will remove the unit and have it tested.
#8 Posted : Thursday, February 26, 2009 5:14:52 PM(UTC)
Tom H
#9 Posted : Saturday, March 7, 2009 6:57:49 AM(UTC)
Tom H
Gene, I replaced the hi limit switch but it apparently was not the problem. The oven display still goes to Pre Heat 100 but no heating takes place. What do you suggest? Remember, the cleaning cycle performed OK with the replacement of the new control panel, but now nothing happens. Could something have over heated during the clean cycle? Tom
#10 Posted : Saturday, March 7, 2009 6:41:13 PM(UTC)
Tom,
Did you check the hi limit switch for continuity before you replaced it?
Fan at bottom has difficulty restarting (Refrigerator & Freezer Repair)
by JeffLam 6/10/2011 6:15:48 AM(UTC)
Bottom Heating Element Doesn't Work (Oven Repair (including Ranges and Cooktops))
by ghrichards 10/9/2010 7:47:54 AM(UTC)
Bottom Hinge pin bracket stripped (Refrigerator & Freezer Repair)
by gonoles31 3/3/2010 5:21:28 AM(UTC)
bottom heating element in oven (Oven Repair (including Ranges and Cooktops))
by billham 4/12/2009 4:55:07 AM(UTC)
bottom heating elemnet (Oven Repair (including Ranges and Cooktops))
by leonbeaudin 3/29/2009 8:31:38 AM(UTC)
Bottom heating element won't heat up (Oven Repair (including Ranges and Cooktops))
by mshufro 3/20/2009 4:13:09 PM(UTC)
Tom H (Oven Repair (including Ranges and Cooktops))
by Tom H 3/13/2009 11:07:38 AM(UTC)
Bottom heating element in oven not heating (Oven Repair (including Ranges and Cooktops))
by Bill Pitts 3/6/2009 10:00:29 AM(UTC)
Kenmore Freezer Door Bottom Hinge (Refrigerator & Freezer Repair)
by ARNOLDJONES 7/7/2008 6:14:09 PM(UTC)
2 Pages12>
