We just bought a used Amana double oven and one of the plastic rings that holds the buttons up on the control panel is missing (Bezel, 5 button black # AP4279960). I've located the part, its a special order. So once I have the part my question is, how easy or hard is it to replace, and step by step instructions would be great.
As you can see on the picture there are a few locking tabs on the inner side of the Bezel. Gene.
thanks Gene, I see that and dont think that will be too hard to figure out; but how do I get the buttons to stay within the Bezel? As of right now they are falling inside the control panel and Im nervous I will just make it worse bu just snapping the bezel into place with makeing sure the buttons are pulled out. I'm sure once I get the part I can figure it out. Cuase I know the bezel just locks in there but dont know how the buttons lock into the bezel. Thanks again
