Help!! We had to replace the bottom element and since doing that our oven will not heat up at all. Display works and stovetop works.Just no heat on either element.:mad:
Check the connections at your control board behind the upper rear panel and ensure they are all connected. The board is the only common between the two elements so if you have voltage going to it (as indicated by the display working) then either the control relays have failed, or some wiring came unplugged behind the lower access panel. Turn the power off, remove the rear panels and have a look. And if you have access to a multimeter, then we can try some more detailed tests.
