| » Jenn-Air Bottom Oven Light Won't Turn Off |
Model Number: JJW9630DDS Brand: Jenn-Air Age: 1 - 5 years
The oven light in our bottom oven will not turn off. I've manually pressed the switch at the bottom with the door open but no luck.
The switch for the top oven still works, and when I manually press it it makes a "clicking" sound and shuts off the light. The bad switch at the bottom makes no clicking sound when I push it. So to me, this sounds like the switch needs replacing. If so, is this something a relatively decent do-it-yourselfer can accomplish? I have not removed the panel yet. Also, is it safe to remove the light bulb at the bottom so it doesn't burn out, or should I just leave it be until I can repair it? Any help would be much appreciated. Ads By Google Related Models |
But for those who have the same problem - ours was that the two small screws holding the "pole" to the switch were loose. Kill the power to the oven, remove the top panel, pull out the switch and make sure these small screws are tight. Tighten them with a small screwdriver (eyeglass repair type) if not. This worked for us.
| Display Modes | |
| Kenmore Oven Bottom Burner Will Not Light | kfost | Oven Repair (including Ranges and Cooktops) | 0 | 03-06-2011 12:19 PM |
| Jenn-air oven won't light | bigpapahawk | Oven Repair (including Ranges and Cooktops) | 0 | 10-10-2010 04:58 AM |
| GE Oven will not light top or bottom burners | luther1500 | Oven Repair (including Ranges and Cooktops) | 7 | 03-26-2010 04:03 AM |
| Bottom oven broiler won't turn off | Timmy3090 | Oven Repair (including Ranges and Cooktops) | 0 | 03-15-2010 05:53 PM |
| Jenn-Air oven will not turn off | teegee | Oven Repair (including Ranges and Cooktops) | 2 | 03-14-2009 05:25 AM |
