I used oven last night without a problem. Tonight no heat, only the cooktop works. Light on display panel work. I have had an issue with the door switch clicking if you lean on the door. Is this the thermal fuse?
THIS FORUM IS DEAD!!!!!!! |
help!! I'm having the same problem. Replaced the element because it burnt out now no heat at all
Tertam
Please start your own thread with the Make and Model Number of your stove use POST NEW TOPIC
Also a description of the original problem, how you diagnosed it, what you did and what is happening now. |
Originally Posted by: djgeorge I used oven last night without a problem. Tonight no heat, only the cooktop works. Light on display panel work. I have had an issue with the door switch clicking if you lean on the door. Is this the thermal fuse? No, the broiler does not work either. This seems to be a common problem with this oven. Does this part have to be replaced every 4 years.
Does this happen often for this oven?Is it worth fixing
Does this happen often for this oven? Sorry I do not have enough experience with this unit to comment
Is it worth fixing At approximately $225.00 for the board and $23.00 for a new overlay (you may not need this). It is pricey. So it depends on how much the unit is worth new and what kind of shape it is in and your overall satisfaction with it before it broke.
Hopefully someone experience on this unit will jump in and help advise you OR You may want to start a new thread with this exact question. |
thank you...oven sells for 1500.00
