Discuss
Troubleshooting Help Needed
 in
Nothing gets hot. The stove top indicator lights come on but none get hot. Also, neither oven gets hot and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Troubleshooting Help Needed
  #1 (permalink)
Old 11-10-2007, 11:40 AM
bobar bobar is offline
Junior Member
bobar is on a distinguished road
Default Troubleshooting Help Needed
Model Number: RCI-639VK   Brand: Frigidaire   Age: More than 10 years
Nothing gets hot. The stove top indicator lights come on but none get hot. Also, neither oven gets hot and the indicator light for either oven does not come on unless a stovetop burner is also on
Also-Model Number is a RE-629VK
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-10-2007, 08:50 PM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default voltage
I would check the in coming volts.
  #3 (permalink)
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi bobar
The first thing I would check is the circuit breaker for the range.
It suppose to be a double breaker which providing 120V through each breaker and 240V total.
If one of the breakers is off or broken, then only 120V is coming to the range which is enough for the indicator lights, but is not enough for any of the heating elements. They need 240V.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune Help Needed - LR code vtcyclist Washer Repair 2 11-14-2007 10:59 AM
25A 277V AC heater switch needed AaronLorr Heating, Ventilation, and Air Conditioning (HVAC) 3 11-12-2007 05:15 PM
Dryer door seal (gasket) - adhesive needed? asc Dryer Repair 0 10-26-2007 05:52 PM
dishwasher instructions to replace complete motor and pump assembly needed Nancy Ramsey Dishwasher Repair 0 10-25-2007 01:22 PM
Bosch SHU dishwasher troubleshooting chart StratLou Dishwasher Repair 1 08-29-2007 03:28 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
