Discuss
Inglis oven has power, won't heat anywhere (oven or 4 elements)
 in
Hello, my inglis 2008 oven has power, but the elements won't get hot at all or the oven. The lights
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Inglis oven has power, won't heat anywhere (oven or 4 elements)
  #1 (permalink)
Old 05-28-2011, 01:24 PM
Junior Member
thegodfiza is on a distinguished road
Default Inglis oven has power, won't heat anywhere (oven or 4 elements)
Brand: -other-   Age: 1 - 5 years
Hello, my inglis 2008 oven has power, but the elements won't get hot at all or the oven. The lights all work beside the switches, and the oven light, and the clock, and i can set the timer and heat and that's all good. But the 4 elements won't turn on or get hot, neither will the oven. I have tried changing the outlet in the wall that the oven plugs into, and still the same problems... Help please!
Ads By Google
  #2 (permalink)
Old 05-29-2011, 05:36 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Have you actually checked the power with a meter?
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore range made loud bang and now no power to the oven elements Lisanepa71 Oven Repair (including Ranges and Cooktops) 0 03-07-2011 09:43 AM
Both oven elements won't heat. Al M Oven Repair (including Ranges and Cooktops) 3 11-08-2010 12:16 PM
Both new oven elements won't heat thomasvanderhoof Oven Repair (including Ranges and Cooktops) 7 10-22-2010 06:05 AM
Oven elements won't heat up. murphk1 Oven Repair (including Ranges and Cooktops) 1 08-10-2010 03:09 AM
No Power To Oven Or Top Elements holapaw12 Oven Repair (including Ranges and Cooktops) 2 01-17-2010 09:56 PM
