Discuss
oven control removal
 in
I would like to know how I remove the control panel part # WB27K5306 in this model of range.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven control removal
  #1 (permalink)
Old 11-10-2007, 06:31 AM
ericnor ericnor is offline
Junior Member
ericnor is on a distinguished road
Default oven control removal
Model Number: JSP40WOW2WW   Brand: GE   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-10-2007, 09:06 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi ericnor
In order to get access to the control board you have to remove screws on each side of the top and bottom of the control panel. Then pull the bottom of the control panel toward yourself and push it up to release the top from the tabs on the back panel. Possible, you'll have to remove the rear panel too.
Do not forget to turn the power off first.
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven control ganderso Oven Repair (including Ranges and Cooktops) 1 11-07-2007 04:03 PM
Front Control Panel Removal dwfunk32 Oven Repair (including Ranges and Cooktops) 0 10-05-2007 10:13 AM
Control Panel Removal PeteME Dishwasher Repair 1 10-03-2007 08:55 PM
oven control dark Earlandtrudyg Oven Repair (including Ranges and Cooktops) 0 08-29-2007 04:11 PM
Ge Oven Control jmajda12 Oven Repair (including Ranges and Cooktops) 1 08-15-2007 05:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
