danpittman
#1 Posted : Friday, May 27, 2011 5:06:01 AM(UTC)
danpittman
the broil works. but in baking the oven warms up some but the bottom element doesn't seem to heat.
#2 Posted : Friday, May 27, 2011 5:32:47 AM(UTC)
A model number may help others help you.
Model Number Locator
Could be your bake element is shot.
Unplug/remove power from the unit.
Undo the screw/s holding the bake element to the back of the unit.
Gently pull the element into the oven.
Remove it's connections and check it with a meter, should be around 20 ohms.
It is a good idea to clip something (clothespin etc.) to the wires so that they do not disappear into the back of the oven.
It is very important to remove power from the unit as even with the oven shut off many units still have power going to one side of the element.
Whirlpool Gold oven shuts off when temp changed (Oven Repair (including Ranges and Cooktops))
by texicus 9/24/2015 9:30:38 AM(UTC)
Whirlpool Gold oven wont bake, turn it on and reads LO (Oven Repair (including Ranges and Cooktops))
by GWHunter 5/6/2015 9:48:20 AM(UTC)
Whirlpool Gold Oven Doesnt Bake Or Broil (Oven Repair (including Ranges and Cooktops))
by SHAYJ1 9/25/2014 9:44:31 AM(UTC)
Whirlpool Gold Oven Overheating (Oven Repair (including Ranges and Cooktops))
by bigdaddy2013 11/21/2013 6:47:58 PM(UTC)
Whirlpool Gold oven - Error code E1 F3 (Oven Repair (including Ranges and Cooktops))
by Jorioux 7/24/2013 5:22:15 PM(UTC)
Whirlpool Gold Oven - E2F3 Code and Broiler Comes on by itself!! (Oven Repair (including Ranges and Cooktops))
by Kentuckypunk 12/11/2012 5:44:12 PM(UTC)
Whirlpool Gold oven no light on control panel and will not work (Oven Repair (including Ranges and Cooktops))
by domjaq@hotmail.com 10/6/2011 10:18:57 AM(UTC)
whirlpool gold oven PF error code (Oven Repair (including Ranges and Cooktops))
by pkanning 7/6/2011 5:15:08 PM(UTC)
