Discuss
Viking gas cooktop disassembly?
 in
Having ignitor issues, but can't even get inside this thing to troubleshoot...is it sealed like a tin can?
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Viking gas cooktop disassembly?
  #1 (permalink)
Old 11-09-2007, 04:54 PM
slednerd slednerd is offline
Junior Member
slednerd is on a distinguished road
Default Viking gas cooktop disassembly?
Model Number: vgsu101   Brand: -other-   Age: 1 - 5 years
Thanks,
John
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-12-2007, 11:58 AM
Junior Member
Default Got it...
Thanks to some help from fixya.com...
Remove grates, burner rings and knobs, shut off gas, unplug cooktop, remove whatever is holding down your cooktop to the counter, and dismount the cooktop. Set the cooktop down supported so it's fairly level, and unscrew the brass rings in the middle of the burners. They have two small opposed notches to put some kind of something in to turn them counterclockwise. I used a couple of putty knives and a gasket scraper like spanner/screwdrivers. BTW, make sure you remove the cooktop before you disassemble...if you release the top with it in the countertop, it will fall through (no, I didn't do this, but almost). Also watch the o-rings under the burner bases. They get brittle from the heat, I guess, and break easily.
More disassembly info...
There is an aluminum coupler between the burner bases and the venturi tube. It is technically part of the venturi tube, but I had one unscrew there instead of at the brass ring. You can still disassemble the cooktop, even if they ALL do this, but you will need to separate this coupler from the brass ring in order to change out the burner bases. No big deal, just a LITTLE penetrating oil on the threads, a pair of chanel locks on the back, and turn it out carefully. If your cooktop is older, and there is a lot of corrosion on these threads, it might be difficult here... When you get the coupler out, re-install it onto the venturi tube. I used a LITTLE regular gas pipe plumbing thread sealant on these threads, as it seemed there was something on there originally...I don't know if this is the right thing to use, probably not.
My switches all check out good with the multimeter, but looks like I have one bad piezio element. Hopefully that will fix it.
Update...can't get just the piezio ignitor element from Viking, must buy the whole burner base. Ridiculous, since I can see the c-clip that is holding it in, and i know these are an off-the-shelf item supplied to Viking by and outside vendor, I just don't know where to get them. The burner base is $28, instead of replacing a $1 part... Also, if you are replacing, or even removing burner bases, you will probably want new o-rings. They look like high temp silicone to me, and Viking gets between $5-$8 apiece...ouch.
Re-assembled cooktop, left unplugged, waiting on parts...
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cooktop igniters bobertj Oven Repair (including Ranges and Cooktops) 6 10-18-2008 08:25 PM
stop the sparks Viking Gas cook top Tommy T. Oven Repair (including Ranges and Cooktops) 3 01-22-2008 12:58 AM
replacing cooktop kenvan Oven Repair (including Ranges and Cooktops) 1 10-27-2007 03:47 PM
G.E. cooktop Jeff Miller Oven Repair (including Ranges and Cooktops) 1 10-19-2007 05:13 PM
Cooktop lite Stu Mills Microwave Repair 0 08-24-2007 12:23 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
