Discuss
Thermador Cooktop - burner sparks but no gas flow
 in
I have a 5 burner 36" wide gas cook top from thermador. The center front burner does not light
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Cooktop - burner sparks but no gas flow
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-09-2007, 12:07 PM
dmullerd dmullerd is offline
Junior Member
dmullerd is on a distinguished road
Default Thermador Cooktop - burner sparks but no gas flow
Model Number: SGCS365RS   Brand: Thermador   Age: 5 - 10 years
I have a 5 burner 36" wide gas cook top from thermador. The center front burner does not light even though the burner sparks just fine. I've also noticed that when I try to turn it on the gas does not flow at all. I'm generally very handy with fixing things and hope I don't have to make a service call. Any thought?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-24-2007, 10:34 AM
WilliamB WilliamB is offline
Junior Member
WilliamB is on a distinguished road
Default
I am having the identical problem, but with the center rear burner. I believe that it may be either the burner solenoid, or the potentiometer, but I am unable to get to the parts in question. How do I remove the cook top?
  #3 (permalink)
Old 11-25-2007, 06:01 PM
chrisw chrisw is offline
Junior Member
chrisw is on a distinguished road
Default
There are 4 screws that need to be removed to take off the front panel. Once it's off, there are huge nut looking screws on top of each burner that need to be removed. Once you have them off, the cooktop pops right off. Please let me know if you figure this out because I have a similar problem but it applies to the entire left side of my RDSS30. One of my burners go out intermittently and there is no gas flow while the other one lights fine but there is a slight bang when either left side burner starts to spark.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Cooktop Sparking Matt Schauer Oven Repair (including Ranges and Cooktops) 14 08-15-2008 05:35 PM
thermador range extra low burner not lighting BILL20850 Oven Repair (including Ranges and Cooktops) 0 10-08-2007 02:44 PM
Thermador Cooktop Help jojo77 Oven Repair (including Ranges and Cooktops) 0 09-29-2007 12:04 PM
Pop, Sparks, No Response novice skills Microwave Repair 1 08-21-2007 01:52 AM
water flow valve BRAND001 Washer Repair 0 07-23-2007 07:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
