Discuss
beeping oven
 in
A friend is remodeling and gave me his Kenmore double oven, model # 911.48485992, SN OV6 45840Q. I installed it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » beeping oven
  #1 (permalink)
Old 02-09-2009, 02:05 PM
rndbdn rndbdn is offline
Junior Member
rndbdn is on a distinguished road
Default beeping oven
Brand: Kenmore   Age: 1 - 5 years
I installed it yesterday, and at first, everything worked fine, but after 5 or 10 minutes, it started beeping, and some of the functions on the lower oven quit working. It beeped randomly all night, but there are no error codes, and the upper oven still works. I have cut the power to the control module several times, and it will reset and work again each time, until after 5 minutes it starts beeping again, with the top oven working and the lower not working.
The control module is a GE WB27T10282. I would like to know if replacing it will most likely solve this problem. The part is over $200, and I don't think it is returnable.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Double oven keeps beeping and going out SheilaEB Oven Repair (including Ranges and Cooktops) 0 12-06-2009 03:37 PM
Kitchen Aid Oven Keeps Beeping AARON baseball Oven Repair (including Ranges and Cooktops) 2 09-18-2009 05:10 AM
Jenn-air Beeping/oven Lock rlolle Oven Repair (including Ranges and Cooktops) 2 08-22-2009 08:10 PM
Kenmore Oven Pop noise and then constant beeping (bad control board) mreddy Oven Repair (including Ranges and Cooktops) 0 01-21-2009 02:42 PM
GE Oven continuos beeping jrzfamily Oven Repair (including Ranges and Cooktops) 1 10-14-2008 05:12 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
