| » Jenn-Air Wall Oven display |
Model Number: ww27430 Brand: Jenn-Air Age: More than 10 years
I have a Jenn-Air ww27430 Double wall oven that is having some issues. About a week ago the display dimmed to a point where it was impossible to see the read out on the LED display, but the oven worked and was functioning. Last night I took it apart thinking there might be a bulb that I could replace. Seeing that there was no servicable parts, I put it back together. All I did was to disconnect the control board from the door and then reconnect it. The connections only go on one way. When I reconnected the electric connection, an alarm goes off on the control panel itself and will not shut off. The oven no longer works and the only switch that seems to work on a temporary basis is the cancel and oven light. I left the electric connection off overnight and now asking for your advise.
Thanks- |
Quote:
DPBAMS@AOL.COM,
Which part did you replace: the membrane switch or the control board (aka clock)? The model number WW27430 is incomplete. There suppose to be one or two more letters after 0. Also what is the color of the control panel? Gene.
__________________
Professional appliance repair in Los Angeles, California. |
tyke58,
If the display is dimmed then the display board (aka clock) has to be replaced. No doubt about it. The went off alarm could be because of loose ribbon connection or broken ribbon. Try to reconnect it and if it would not work then the membrane switch has to be replaced. The model number WW27430 is incomplete. There suppose to be one or two more letters after 0. Also what is the color of the control panel? Gene.
__________________
| Display Modes | |
| Please Help! Jenn Aire Clock Display | abbymac | Oven Repair (including Ranges and Cooktops) | 2 | 11-01-2007 11:41 AM |
| Thermador wall oven | bartt21999 | Oven Repair (including Ranges and Cooktops) | 0 | 10-30-2007 10:23 AM |
| wall oven wont go below 350 | david93950 | Oven Repair (including Ranges and Cooktops) | 0 | 10-27-2007 12:01 PM |
| Wall Oven | Lee | Oven Repair (including Ranges and Cooktops) | 1 | 10-16-2007 12:25 PM |
| Tappan Wall Oven | jake | Oven Repair (including Ranges and Cooktops) | 3 | 08-13-2007 11:53 PM |
