Just today, replaced the oven sensor with a part I ordered from you. Did not solve anything. When I set the Bake Temp, as soon as it accepts that the digital reading of the oven temp comes on at a temp over 300 degrees - and the oven is cold. Then it shuts off the pre-heating at a temp well below the set temp - generally several hundred degrees lower. I am at a loss.
