Discuss
Oven control
 in
I have a Canadian-made KitchenAid range. The Model number differs slightly from the U.S. version, i.e., mine
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven control
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-07-2007, 01:18 PM
ganderso ganderso is offline
Junior Member
ganderso is on a distinguished road
Default Oven control
Model Number: YKERC507EW3   Brand: Kitchen Aid   Age: 5 - 10 years
I have a Canadian-made KitchenAid range. The Model number differs slightly from the U.S. version, i.e., mine is YKERC507EW3. I believe the corresponding U.S. version is KERC507WH3.
The touchpad is erratic. Sometimes when inputting in the Timer function, the display will instead show up in the Temp. control, i.e., if setting 5:00 minutes in Timer mode, instead the display will show 500 degrees oven temp. has been set. The oven will then heat to 500 degrees, and the intended 5:00 minute timer does not register. Also, the oven heat seems to be innaccurate, sometimes spontaneously going into Broil mode.
I suspect the Oven control, Whirlpool Part AP2995057 should be replaced.
I understand you don't ship to Canada, but I have a U.S. shipping destination.
Please advise if the above named part is likely to fix the problem, and if I am correct in assuming compatibility between the Canadian and U.S. Model numbers given.
Thanks a lot.
Gerry
Calgary, AB
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-07-2007, 03:03 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Gerry
Yes, you were right. Most likely the problem is a bad control and replacing it should solve the problem.
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need oven control for old GE stove DaveSemm Oven Repair (including Ranges and Cooktops) 0 10-31-2007 10:11 AM
GE oven control module droper Oven Repair (including Ranges and Cooktops) 3 10-15-2007 06:43 PM
Ge Oven Control jmajda12 Oven Repair (including Ranges and Cooktops) 1 08-15-2007 04:19 PM
GE Oven control connectioins ramsfanjeff Oven Repair (including Ranges and Cooktops) 0 08-14-2007 03:30 PM
Electronic Oven Control andye Oven Repair (including Ranges and Cooktops) 3 08-01-2007 07:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
