I need to replace the triple-heating zone element on the right front of the range. Any advice on how to get to it (underneath a glass top).
Originally Posted by: 4km I need to replace the triple-heating zone element on the right front of the range. Any advice on how to get to it (underneath a glass top). 4KM, To replace the burner element, you'll need to remove the glass cooktop, Here are some general instructions from the service manual, it covers several models, you wont need to do every step. Maintop Assembly
1. Remove power from unit. 2. Remove range from installation position, see “Removing and Replacing Range” procedure. 3. Remove air grill, filter, grill grates, aeration pan and cartridges (select models). 4. Remove screws from plenum area at front of opening. 5. Open oven door and remove screws securing maintop to oven chassis, located on the bottom of control panel and along the outside edges of the maintop. 6. Remove cartridge receptacles and grill pans (select models). 7. Label and disconnect wiring to elements (select models).
8. Remove screws securing element mounting brackets to main top assembly (select models). 9. Gently remove elements from mounting brackets to prevent damage to glass top (select models). 10.Reverse procedure to reinstall maintop assembly.
Good Luck, :) :) :)
