Discuss
Removal of glass cooktop
 in
Saw a couple of postings on the subject but couldn't access the reply instructions. I need assistance on how
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Removal of glass cooktop
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-07-2007, 10:29 AM
danhair danhair is offline
Junior Member
danhair is on a distinguished road
Post Removal of glass cooktop
Model Number: CCE3531W   Brand: Jenn-Air   Age: 1 - 5 years
Saw a couple of postings on the subject but couldn't access the reply instructions. I need assistance on how to remove the glass top (beyond taking the knobs and grammets off) from our cooktop stove. I read there's an adhesive tape underneath Not sure how to approach its removal correctly. Also, should I purchase replacement tape prior to getting started?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-07-2007, 11:27 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi danhair
Turn off the circuit breaker for the stove, remove the stove from the counter top and turn it around in any direction to let the stove rest on the counter top. Remove all screws around the burner box and careful lift up the glass top.
- Here are the break down diagrams for the Jenn Air stove Model CCE3531W
Good luck.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 11-07-2007, 04:39 PM
Junior Member
Default
Thanks Gene. I was hoping for more details about how to remove the stove from the counter top. Do I approach that from the underneath inside the cabinet? If so how is it attached and at how many places?
  #4 (permalink)
Old 11-07-2007, 05:00 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, you do have to approach from inside of the cabinet. Also, check how it was attached to the counter top. I've seen many times when people used a caulk or even a glue to seal a space between a glass top and a counter top. Mostly it depends on the installers qualification.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Glass Cooktop victordbeat Oven Repair (including Ranges and Cooktops) 2 07-29-2008 05:38 PM
Glass Cooktop Replacement HBar Oven Repair (including Ranges and Cooktops) 2 07-24-2008 03:52 AM
Replacing Glass Cooktop victordbeat Oven Repair (including Ranges and Cooktops) 0 11-04-2007 07:10 AM
Cooktop replacement glass JNM Oven Repair (including Ranges and Cooktops) 2 10-19-2007 10:58 AM
Replacing glass cooktop jennifer Oven Repair (including Ranges and Cooktops) 2 08-13-2007 11:46 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
