wE RECENTLY HAD TO REPLACE THE BAKE ELEMENT, SUCCESSFULLY....AND THEN HAD TO REPLACE THE ELECCTRONIC CLOCK CONTROL ALSO SUCCESSFULLY.....HOWEVER, NOW THE OVEN FAN WILL NOT SHUT OFF. wE SUSPECT A RELAY SWITCH OR SHORT ON THE BOARD, BUT DO NOT KNOW HOW TO FIND THE FAN CONNECTIONS OR HOW TO FIX THIS PROBLEM. CAN ONLY TURN THE FAN OFF IF WE CUT THE ELECTRIC TO THE UNIT. cAN ANYONE HELP US OR DIRECT US TO THE APPROPRIATE REPAIR?????
tHANKS, FRANCINE
