I ordered a replacement part for a burned out element. The connectors on the new part are placed differently from the original. I need to know how to remove the wires from the original element and then to attach them to the new part. The difference is that the connectors on the new part are side-by-side with one prong of one connector actually attached to one prong of the other connector. The original part has about a 2 inch separation between connectors. Thanks!
