Discuss
oven not heating to set temperature
 in
The Elements Are Good, I Replaced The Oven Temperature Sensor, Still Not Working. Whats Wrong With This Thing??? Related Models
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven not heating to set temperature
  #1 (permalink)
Old 05-19-2011, 10:57 AM
Junior Member
lagoss is on a distinguished road
Default oven not heating to set temperature
Model Number: LCRE805   Brand: Maytag   Age: More than 10 years
Related Models
Maytag LCRE805 RANGE- S/C F/S ELE
Maytag LCRE883 RANGE- S/C F/S ELE
Maytag LCRG200 RANGE- F/S STD GAS
Maytag LCRG300 RANGE- F/S STD GAS
Maytag LCRG305 RANGE- F/S STD GAS
Maytag LCRG350 RANGE- F/S STD GAS
Maytag LCRG355 RANGE- F/S STD GAS
Maytag LCRG382 RANGE- F/S STD GAS
Maytag LCRG383 RANGE- F/S STD GAS
Maytag LCRG400 RANGE- F/S STD GAS
Maytag LCRG405 RANGE-F/S CONT CLEAN GAS
Maytag LCRG500 RANGE- F/S STD GAS
Maytag LCRG501 RANGE- F/S STD GAS
Maytag LCRG502 RANGE- F/S STD GAS
Maytag LCRG505 RANGE- F/S STD GAS
Maytag LCRG560 RANGE- F/S STD GAS
Maytag LCRG583 RANGE-F/S CONT CLEAN GAS
Maytag LCRG600 RANGE- F/S STD GAS
Maytag LCRG601 RANGE- F/S STD GAS
Maytag LCRG602 RANGE-F/S CONT CLEAN GAS
Maytag LCRG700 RANGE- S/C F/S GAS
Maytag LCRG705 RANGE- S/C F/S GAS
Maytag LCRG750 RANGE- S/C F/S GAS
Maytag LCRG755 RANGE- S/C F/S GAS
Maytag LCRG760 RANGE- S/C F/S GAS
Maytag LCRG760A RANGE- S/C F/S GAS
Maytag LCRG783 RANGE- S/C F/S GAS
Maytag LCRG800 RANGE- S/C F/S GAS
Maytag LCRG805 RANGE- S/C F/S GAS
Maytag LCRG860 RANGE- S/C F/S GAS
Maytag LCRG860A RANGE- S/C F/S GAS
Maytag LCRP200 RANGE- F/S STD GAS
Maytag LCRP205 RANGE- F/S STD GAS
Maytag LCRP300 RANGE- F/S STD GAS
Maytag LCRP382 RANGE- F/S STD GAS
Maytag LCSE600 SURFACE UNIT- ELE
Maytag LCSE601 SURFACE UNIT- ELE
Maytag LCSG500 SURFACE UNIT- GAS
Maytag LCSG501 SURFACE UNIT- GAS
Maytag LCSG560 SURFACE UNIT- GAS
Maytag LCSG600 SURFACE UNIT- GAS
 LCU240CP Air Conditioner
 LCU340CP Air Conditioner
Amana LD10 COMMERCIAL MICROWAVES
Amana LD10D COMMERCIAL MICROWAVES
Amana LD10D2 COMMERCIAL MICROWAVES
Amana LD10MP COMMERCIAL MICROWAVES
Amana LD10MPS COMMERCIAL MICROWAVES
 LD25EL Dehumidifier
 LD40 Dehumidifier
 LD40E Dehumidifier
 LD50EBL Dehumidifier
 LD50EL Dehumidifier
 LD50ELY5 Dehumidifier
Amana LD510 COMMERCIAL MICROWAVES
Amana LD510D COMMERCIAL MICROWAVES
Amana LD510M COMMERCIAL MICROWAVES
Amana LD510P COMMERCIAL MICROWAVES
Amana LD510S COMMERCIAL MICROWAVES
 LD65EL Dehumidifier
 LD65ELY5 Dehumidifier
Gaggenau LD816-610
Gaggenau LD816-620
 LDC22720ST Refrigerator
 LDC22720SW Refrigerator
 LDC22720TT Refrigerator
Admiral LDE1000ACE DRYER- ELE
Admiral LDE1000AKE DRYER- ELE
Admiral LDE1000GGE DRYER- ELE
Maytag LDE110 DRYER- ELE
Maytag LDE18CA MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CM MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE18CT MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE19CA MANUAL, PARTS (DRYER ELE)
Maytag LDE19CD MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE19CS MANUAL, PARTS (DRYER ELE)
Maytag LDE19CT MANUAL, PARTS (DRYER ELE)
Maytag LDE210 DRYER- ELE
Maytag LDE212 DRYER- ELE
Maytag LDE21CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE22CS MANUAL, PARTS (DRYER ELE)
Maytag LDE22CT MANUAL, PARTS (DRYER ELE)
Maytag LDE23CD MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CA MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CM MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE24CT MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE25CS MAYTAG LAUNDRY (DRYER ELE)
Maytag LDE26CA MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE26CD MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE26CS MANUAL, PARTS (DRYER ELE)
Maytag LDE26CT MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE27CA MANUAL, PARTS (DRYER ELE)
Maytag LDE27CD MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag LDE27CS MANUAL, PARTS (DRYER ELE)
Maytag LDE27CT MANUAL, PARTS (DRYER ELE)
Maytag LDE303 DRYER- ELE
Maytag LDE312 DRYER- ELE
Maytag LDE313 DRYER- ELE
Frigidaire LDE333PBW0 Frg(v0) / Gas Dryer
Frigidaire LDE333PBW1 Frg(v0) / Electric Dryer
Frigidaire LDE333PEW0 Frg(v0) / Electric Dryer
Maytag LDE382 DRYER- ELE
Maytag LDE4000 DRYER- ELE
Maytag LDE4000ACL DRYER- ELE
Maytag LDE4000ACW DRYER- ELE
Maytag LDE4000ADL DRYER- ELE
Maytag LDE4000ADW DRYER- ELE
Maytag LDE410 DRYER- ELE
Maytag LDE412 DRYER- ELE
Maytag LDE482 DRYER- ELE
Maytag LDE490 DRYER- ELE
Maytag LDE4910 DRYER- ELE
Maytag LDE4910ACL DRYER- ELE
Maytag LDE4910ACW DRYER- ELE
Maytag LDE4914ACE DRYER- ELE
Maytag LDE4914ACL DRYER- ELE
Maytag LDE4914ACM DRYER- ELE
  #2 (permalink)
Old 05-19-2011, 06:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Can you post more detailed description on the problem please?
Here are the breakdown diagrams and Replacement parts for MAYTAG LCRE805 RANGE- S/C F/S ELE | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 05-20-2011, 06:46 AM
Junior Member
Default
GENE, I placed a themometer in the oven and set the temp at 350. the oven temp only reached about 125.
  #4 (permalink)
Old 05-20-2011, 03:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Pull the range out of the wall. Remove the cover and check for 240 VAC to the Bake heating element while the control calls for Bake. If the reading is incorrect, replace the relay board (#25 on the diagram).
- The relay board Part number: AP4102784
__________________
  #5 (permalink)
Old 05-22-2011, 12:50 PM
Junior Member
Default
Gene, I checked the voltage at the element and it checked O.K. Where do you suggest I go from here? A new stove????
  #6 (permalink)
Old 05-23-2011, 12:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Can you describe step by step how did you check the heating elements and the voltage?
__________________
  #7 (permalink)
Old 05-23-2011, 05:00 PM
Junior Member
Default
Gene , I pulled the stove out from the wall, removed the cover from the back of the stove, turned the oven on bake, took my meter and checked the voltage at the element and got a 240 reading, Oh, I did set the oven temp at 350.
  #8 (permalink)
Old 05-23-2011, 07:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You have to remove the wires from any one of the heating element terminals before measuring the voltage and before checking the heating element for continuity as well.
Measure the voltage between each of the wire and the chassis - 120 VAC, and between the wires - 240 VAC.
Turn off the power prior to the continuity test.
__________________
  #9 (permalink)
Old 05-24-2011, 04:20 PM
Junior Member
Default
Gene, I unhooked the wire from the element and checked the continuity, it checked 21.9 ohms. I then checked the voltage on each wire , wire to chassis, I got a reading of 121v and 122v respectively. Next????
  #10 (permalink)
Old 05-24-2011, 04:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Well, everything seems to be good. Put it back together and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven not heating to set temperature rancher1007 Oven Repair (including Ranges and Cooktops) 0 12-31-2010 10:47 AM
Oven not heating at the right temperature ovenprob Oven Repair (including Ranges and Cooktops) 0 03-22-2010 11:28 AM
oven is not heating to right temperature cooldad52 Oven Repair (including Ranges and Cooktops) 10 09-13-2009 06:52 PM
Oven works but not heating to required temperature vaughans Oven Repair (including Ranges and Cooktops) 1 11-21-2008 10:27 AM
Oven not heating to temperature properly fillhardfarm Oven Repair (including Ranges and Cooktops) 0 01-18-2008 07:15 AM
