Discuss
Whirlpool oven won't light
 in
Thank You so much Gene !!
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool oven won't light
  #31 (permalink)
Old 03-23-2012, 04:19 PM
Junior Member
Brunowren is on a distinguished road
Default
  #32 (permalink)
Old 03-23-2012, 04:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #33 (permalink)
Old 04-04-2012, 05:57 PM
Junior Member
Talking Fixed
Well ordered the part on Sunday 4/1 came in Tues 4/3 WOW ... and I had a working oven Tuesday night ...Thank you so much Gene, you saved me a ton of money and made me the Hero of the month !!!
Thank you so much again Sir!!! Your knowledge is a huge help, money saver, and time saver!!! Bless You!
  #34 (permalink)
Old 04-10-2012, 04:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome Eric. Thank you for your good words and for the feedback.
Good luck with your range.
__________________
  #35 (permalink)
Old 05-15-2012, 06:24 PM
Junior Member
Jwillison is on a distinguished road
Default Similar problem
Hi Gene,
Similar problem as above but I would just like to confirm before I buy the part. I have a whirlpool Super capacity 456 model #Sf368lepb2, when turned on it clicks twice but won't heat up. Range works just fine. I tested the electrical thingys on the gas valve. Middle to bottom shows 205 ohms, middle to top shows nothing 0 ohms. Does this mean I need a new gas valve? Thanks for your help
  #36 (permalink)
Old 05-15-2012, 06:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Jwillison View Post
...Middle to bottom shows 205 ohms, middle to top shows nothing 0 ohms. Does this mean I need a new gas valve...
Yes. No doubt about it.
- The gas valve Part number: W10293048
__________________
  #37 (permalink)
Old 09-24-2013, 12:30 PM
Junior Member
Blickster is on a distinguished road
Default Oven won't light but broiler does
Gene or community, our gas Whirlpool GS773LXSSO oven won't light but the broiler works fine. Would this still be the spark module or is this issue something else?
Thanks for your input.
Brian
  #38 (permalink)
Old 05-21-2016, 08:26 PM
Junior Member
EMurphy is on a distinguished road
Default Gas Whirlpool Accubake Oven Wont Light
Good Evening,
I have a Whirlpool Accubake SF362LXSS that will not light the bake or broil element. The stove top is working fine and there are no error codes showing on the display/control panel.
When I turn the oven on in bake mode there is no clicking/ignition or detectable smell of gas.
When I turn the oven on in broil mode there are 2 slow clicks (slower than when it was working), no ignition, and a slight smell of gas.
Any suggestions?
Thanks M...
  #39 (permalink)
Old 06-11-2016, 04:27 AM
Junior Member
Tmoore789 is on a distinguished road
Default
I'm having the same issue. Is this dealt with on another thread?
Thnx! Model SF362LXST
  #40 (permalink)
Old 06-11-2016, 04:32 AM
Junior Member
Default Gas oven won't start
Quote:
Originally Posted by EMurphy View Post
Good Evening,
Any suggestions?
Thanks M...
Model SF362LXST
Thnx!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool oven will not light firefite44 Oven Repair (including Ranges and Cooktops) 5 10-13-2010 04:27 PM
Whirlpool oven will not light gumbo Oven Repair (including Ranges and Cooktops) 0 02-08-2010 01:26 PM
Whirlpool Gas oven won't light Ckline1313 Oven Repair (including Ranges and Cooktops) 0 11-29-2009 05:24 PM
whirlpool oven - won't light badelastic Oven Repair (including Ranges and Cooktops) 0 03-04-2009 03:41 PM
Whirlpool oven won't light tpreston@dc.rr.com Oven Repair (including Ranges and Cooktops) 0 08-12-2007 12:10 PM
