I need a wiring diagram for the replacement part I just received. Why is this such a difficult search and request????????????????????????????
[COLOR="DarkRed"]Why is this such a difficult search and request?[/COLOR]
First it is a GE and they like to keep all tech info a secret so the info you want may not be available anywhere other than GE. Usually if you try to get tech info from them you will have to place a service call.
Second nothing comes up using the given model number I also tried T08C using a zero instead of an o. Please check it.
Third if this is not a USA unit then the odds of getting any info on it are even slimmer. |
THIS FORUM IS DEAD!!!!!!! |
