| » Oven doesn't maintain temp |
Model Number: MERH752BAW Brand: Maytag Age: 1 - 5 years
I purchased my oven about a year and a half ago and I'm currently having a problem that I think may have to do with the clock or part #AP4099018, but I'm not 100% sure. If I set my oven at 350 it might heat up to the temp and it might not, it's inconsistent. If I use a temp of 400-450 the bake light begins flashing after about 10 mins. If I shut the off oven off and turn it back on the temp may only be in the lower 300's. Or I may be able to use it at 350, but after about 10-15 mins it starts to lose temp. I'm not sure if the above listed part would fix my problem. What do you think?
Thanks for your help in advance. Ads By Google Related Models |
If the temperature is fluctuating then the problem most likely is a bad control board.
The part number you posted is correct. Here are the break down diagrams for the Maytag range Model MERH752BAW Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| maytag oven will not maintain temp | davehubert | Oven Repair (including Ranges and Cooktops) | 0 | 12-13-2009 01:40 PM |
| Oven achieves but does not maintain temp | rcoderre | Oven Repair (including Ranges and Cooktops) | 0 | 11-26-2009 04:50 PM |
| Oven won't maintain temp (too low) | Wingman | Oven Repair (including Ranges and Cooktops) | 9 | 10-24-2008 07:06 AM |
| gas oven will not maintain temp after preheat | dlinderoth | Oven Repair (including Ranges and Cooktops) | 0 | 07-09-2008 04:54 PM |
| Oven will not maintain temp. | mark lynn | Oven Repair (including Ranges and Cooktops) | 1 | 07-05-2008 07:36 AM |
