Discuss
Gas smell after oven use but no leak detected
 in
Hello, For awhile now we have been noticing a gas smell sometimes after using the oven part of our stove.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas smell after oven use but no leak detected
  #1 (permalink)
Old 01-28-2009, 10:36 AM
nluiseb nluiseb is offline
Junior Member
nluiseb is on a distinguished road
Default Gas smell after oven use but no leak detected
Brand: GE   Age: 1 - 5 years
Hello,
For awhile now we have been noticing a gas smell sometimes after using the oven part of our stove. We notice the smell a few hours after we’re done using the oven. Usually if we use the oven for dinner, we’ll notice the smell late that same night or the next day (after we get home from work). We’ve narrowed it down and will only smell gas after using the oven part of the stove, not the burners. However, the gas smell isn’t consistent and we don’t smell it every time after using the oven. At first we thought maybe we weren't turning the knobs completely off, but since then we've been very good about making sure they're completely off.
We had Sears Appliance Repair come out to our house and they checked everything about the stove, but could not find a leak. We also borrowed a gas detector from my father’s work (he’s an industrial hygienist) and still did not find a leak, even after smelling gas.
If we turn off the gas to the stove (at the wall), we do not smell gas. We also called our gas/electric utility company and they suggested that it might be a problem with the pipes and to call a heating/cooling contractor. However, we really think that it is a problem with the stove/oven and not the pipes because we only smell gas after using the oven. I would think if the problem was with the pipes, if the gas was left on we would smell gas consistently, which is not the case.
So anyways, we’re unsure of what to do. I guess our next step would be to buy a new stove, but we’re hesitant to do that since the oven itself is fairly new (about 5 years old). Any advice would be appreciated. Thanks!
  #2 (permalink)
Old 01-29-2009, 05:33 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
If the gas leak can not be detected with a special equipment then it could be: a) a very small leak which can not be detected and fixed or b) something else smells like gas. It is very hard to recommend anything in such situation.
__________________
  #3 (permalink)
Old 10-28-2009, 07:57 PM
Rudey Rudey is offline
Junior Member
Rudey is on a distinguished road
Default
Hi.
I am experiencing the exact same issue. Is it possible that some control mechanism or valve is not closing completely when the oven knob is turned to the off position?
I have a old kenmore that was in this house when I bought 9 years ago.
Dan.
  #4 (permalink)
Old 10-29-2009, 03:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Dan,
Everything is possible. Without proper diagnosis it's just a guessing. Have you called a local gas company to detect and pinpoint the leak?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas smell from oven nothing2it Oven Repair (including Ranges and Cooktops) 7 12-29-2008 12:07 PM
Gas oven cooks but can smell gas wittigtc Oven Repair (including Ranges and Cooktops) 3 11-05-2008 01:44 PM
Oven won't light and no gas smell hnkos17 Oven Repair (including Ranges and Cooktops) 0 10-08-2008 11:39 AM
Oven stopped working--no gas detected Nikole Oven Repair (including Ranges and Cooktops) 1 08-17-2008 07:14 PM
gas smell only when oven is on stevencsmith Oven Repair (including Ranges and Cooktops) 1 12-04-2007 12:23 AM
