Discuss
oven & broiler won't lite
 in
I'm not sure of the age of the stove, it was left in the huose I bought. I would
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven & broiler won't lite
  #1 (permalink)
Old 11-05-2007, 12:03 PM
Mike Johnson Mike Johnson is offline
Junior Member
Mike Johnson is on a distinguished road
Post oven & broiler won't lite
Model Number: CGR3740ADL   Brand: Magic Chef   Age: 5 - 10 years
I'm not sure of the age of the stove, it was left in the huose I bought. I would like to know if there is any way to test the broiler & oven igniters. I don't mind buyong teh parts but I don't know if the igniters are bad or if the igniter module is bad. How can I test these components?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-05-2007, 01:13 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Mike
The easiest way is to unplug the igniter (one at a time), turn the oven on and check for 120V coming to the igniter. If you see a proper power then the igniter has to be replaced.
If you do not see a proper power then check the wires and, if there is nothing wrong, replace the control board.
- The part number for the bake and the broil igniters AP205873
- The part number for the control board (aka a clock) AP4309072
- Here are the break down diagrams for the Magic Chef range Model CGR3740ADL
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't lite? Chris7525 Oven Repair (including Ranges and Cooktops) 6 11-12-2007 07:14 AM
oven won't lite adavis Oven Repair (including Ranges and Cooktops) 0 11-04-2007 12:15 PM
Kenmore Gas Oven Will Not lite jennieframe Oven Repair (including Ranges and Cooktops) 0 10-28-2007 09:20 AM
Gas oven slow to lite Rayman Oven Repair (including Ranges and Cooktops) 3 09-12-2007 10:55 PM
GE Oven - Broiler does not work martincregg Oven Repair (including Ranges and Cooktops) 1 09-01-2007 11:46 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
