Discuss
trouble igniting stove
 in
Hello, I have a hotpoint oven, model # RGB744GEV2WH. I sometimes am able to turn it on easily, and sometimes
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » trouble igniting stove
  #1 (permalink)
Old 01-27-2009, 10:48 AM
Junior Member
dinah is on a distinguished road
Default trouble igniting stove
Model Number: RGB744GEV2WH   Brand: Hotpoint   Age: More than 10 years
Hello, I have a hotpoint oven, model # RGB744GEV2WH. I sometimes am able to turn it on easily, and sometimes I need a match to ignite it. When I lift the burners, so that the stick sort of thing that is attached to the oven is showing, and I clean off that part, the range starts to work for a while, but after a while, I have to go back to using matches. Is there something I can fix or replace to avoid this problem?
Ads By Google
Related Models
General Electric RGB744GEV2WH Gas range
General Electric RGB744WEA1WW Gas range
General Electric RGB744WEA2WW Gas range
General Electric RGB744WEA3WW Gas range
General Electric RGB744WET1WW Gas range
General Electric RGB744WET2WW Gas range
General Electric RGB744WEV1WW Gas range
General Electric RGB744WEV2WW Gas range
General Electric RGB745BEA1AD Gas range
General Electric RGB745BEA1CT Gas range
General Electric RGB745BEA1WH Gas range
General Electric RGB745BEA2AD Gas range
General Electric RGB745BEA2CT Gas range
General Electric RGB745BEA2WH Gas range
General Electric RGB745BEA3AD Gas range
General Electric RGB745BEA3CT Gas range
General Electric RGB745BEA3WH Gas range
General Electric RGB745BEA4AD Gas range
General Electric RGB745BEA4WH Gas range
General Electric RGB745BEA5AD Gas range
General Electric RGB745BEA5WH Gas range
General Electric RGB745BEA6AD Gas range
General Electric RGB745BEA6WH Gas range
General Electric RGB745BEA7WH Gas range
General Electric RGB745BEA8WH Gas range
General Electric RGB745BEH1CT Gas range
General Electric RGB745BEH1WH Gas range
General Electric RGB745BEH2CT Gas range
General Electric RGB745BEH2WH Gas range
General Electric RGB745BEH3CT Gas range
General Electric RGB745BEH3WH Gas range
General Electric RGB745BEH4CT Gas range
General Electric RGB745BEH4WH Gas range
General Electric RGB745BEH5CT Gas range
General Electric RGB745BEH5WH Gas range
General Electric RGB745BEH6CT Gas range
General Electric RGB745BEH6WH Gas range
General Electric RGB745BEH7CT Gas range
General Electric RGB745BEH7WH Gas range
General Electric RGB745EEH1BB Gas range
General Electric RGB745EEH2BB Gas range
General Electric RGB745EEH3BB Gas range
General Electric RGB745EEH4BB Gas range
General Electric RGB745EEH5BB Gas range
General Electric RGB745GEH1 Gas range
General Electric RGB745GEN1 Gas range
General Electric RGB745GER1 Gas range
General Electric RGB745GER2 Gas range
General Electric RGB745GER3 Gas range
General Electric RGB745GES1 Gas range
General Electric RGB745GET1AD Gas range
General Electric RGB745GET1WH Gas range
General Electric RGB745GET2AD Gas range
General Electric RGB745GET2WH Gas range
General Electric RGB745GEV1AD Gas range
General Electric RGB745GEV1WH Gas range
General Electric RGB745GEV2AD Gas range
General Electric RGB745GEV2WH Gas range
General Electric RGB745GEV3AD Gas range
General Electric RGB745GEV3WH Gas range
General Electric RGB745SEV1AD Gas range
General Electric RGB745SEV1WH Gas range
General Electric RGB745SEV2AD Gas range
General Electric RGB745SEV2WH Gas range
General Electric RGB745WEA1WW Gas range
General Electric RGB745WEA2WW Gas range
General Electric RGB745WEA3WW Gas range
General Electric RGB745WEA4WW Gas range
General Electric RGB745WEA5WW Gas range
General Electric RGB745WEA6WW Gas range
General Electric RGB745WEA7WW Gas range
General Electric RGB745WEA8WW Gas range
General Electric RGB745WEH1WW Gas range
General Electric RGB745WEH2WW Gas range
General Electric RGB745WEH3WW Gas range
General Electric RGB745WEH4WW Gas range
General Electric RGB745WEH5WW Gas range
General Electric RGB745WEH6WW Gas range
General Electric RGB745WEH7WW Gas range
General Electric RGB745WET1WW Gas range
General Electric RGB745WET2WW Gas range
General Electric RGB745WEV1WW Gas range
General Electric RGB745WEV2WW Gas range
General Electric RGB745WEV3WW Gas range
General Electric RGB746GEJ1 Gas range
General Electric RGB746GEJ2 Gas range
General Electric RGB746GEJ3 Gas range
General Electric RGB746GEJ4 Gas range
General Electric RGB746GEJ5 Gas range
General Electric RGB746GEJ6 Gas range
General Electric RGB746GEJ7 Gas range
General Electric RGB746GEJ8 Gas range
General Electric RGB746GEJ9 Gas range
General Electric RGB746GEJA Gas range
General Electric RGB746GEN1 Gas range
General Electric RGB746GES1 Gas range
General Electric RGB746HED1CT Gas range
General Electric RGB746HED1WH Gas range
General Electric RGB746HED2CT Gas range
General Electric RGB746HED2WH Gas range
General Electric RGB746HED3CT Gas range
General Electric RGB746HED3WH Gas range
General Electric RGB746HEH1CT Gas range
General Electric RGB746HEH1WH Gas range
General Electric RGB746WEH1WW Gas range
General Electric RGB746WEH2WW Gas range
General Electric RGB746WEH3WW Gas range
General Electric RGB746WEH4WW Gas range
General Electric RGB746WEH5WW Gas range
General Electric RGB746WEH6WW Gas range
General Electric RGB747GEP1 Gas range
General Electric RGB747GER1 Gas range
General Electric RGB747GER2 Gas range
General Electric RGB747GER3 Gas range
General Electric RGB750SEY1WW Gas range
General Electric RGB751GEL1 Electric range
General Electric RGB790BEK1BB Gas range
General Electric RGB790CEK1CC Gas range
General Electric RGB790SEH1SA Gas range
General Electric RGB790SEH2SA Gas range
  #2 (permalink)
Old 01-27-2009, 01:12 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
if you are talking about the oven part you need to replace the oven ignitor coil, it is not glowing bright enough to send power back to the gas valve to open it. the part # is wb13k04 tom ******************************************** - parts
  #3 (permalink)
Old 01-27-2009, 09:22 PM
Junior Member
Default
Quote:
thanks for your reply. i actually don't have a problem with the oven. just the stove. i just checked parts available, and it seems that i need to keep cleaning the orfice spud (part #3 for this model) or else i unpredictably just get a clicking sound when i try to ignite the stove, and i need to use a match to get it going. often the stove works, but sometimes only a match will do. does it make sense to replace the orfice spud, or is the problem likely to really be elsewhere? my burners are clean and i don't see any clogging.
thanks.
  #4 (permalink)
Old 01-28-2009, 05:54 AM
Senior Expert
APP Volunteer
Default
I would try to replace the orifice spud, but I wonder if the spark is strong enough. Some times the spark module loses power, and you have to replace it. Tom ********************************************
  #5 (permalink)
Old 01-28-2009, 08:10 PM
Junior Member
Default
How can I check if the spark is strong enough- does it help that often the burner does work, or can the clicking I hear when it does not work indicate anything about the spark module? Also, am I able to replace the orfice spud myself, or does it have to be professionally installed?
  #6 (permalink)
Old 01-29-2009, 06:07 AM
Senior Expert
APP Volunteer
Default
If I remember right the orfice spud will unscrew out. On the spark ignitor, I have been doing this for a long time, I could just tell, that the spark is soft, instead of the normal hard snap it makes. Tom ********************************************
Reply
« Danny | amana range »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
magic chef stove not igniting Michael Robinson Oven Repair (including Ranges and Cooktops) 3 12-29-2009 02:09 PM
Stove knob trouble jlib17@yahoo.com Oven Repair (including Ranges and Cooktops) 0 12-22-2009 05:00 PM
Stove trouble Janice Brock Oven Repair (including Ranges and Cooktops) 0 04-23-2009 09:13 AM
Amana Stove Ignitor Trouble acostafam Oven Repair (including Ranges and Cooktops) 1 11-12-2008 08:19 PM
gas stove igniting problem ScrappyBlue Oven Repair (including Ranges and Cooktops) 1 09-22-2008 05:59 PM
