Discuss
Burner only operates at high, ignores setting on know
 in
I had a series of problems with my stove that all started from the seal on the cooktop wearing out.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Burner only operates at high, ignores setting on know
  #1 (permalink)
Old 01-27-2009, 08:44 AM
Junior Member
SLorenson is on a distinguished road
Default Burner only operates at high, ignores setting on knob
Model Number: CHE9830BCE   Brand: Maytag   Age: More than 10 years
I had a series of problems with my stove that all started from the seal on the cooktop wearing out. This resulted in liquid dripping thru onto the control panel. I resealed it and replaced several parts and eventually thought all was back to normal.
Around a month later, my right front element failed (large). I thought it was a natural part of an aging stove and replaced it. When I replaced it, I discovered what appeared to be a piece of the sealant (silicon?) in the burner, between the coils and the glass.
The new element only works on high, i.e. it doesn't matter what I set the knob too, it gets very hot and stays that way. (Off turns if off fine, its the other settings that seem to have no effect). Did I hook up the wires wrong, should I find a wiring diagram and trace them out? I tried switching the wires around in case I had gotten confused when reattaching and did not seem to get the desired results, but I did not try all 16 possible combinations. In that process I may have forgotten which was the original (proper) way to be connected. Is the element defective? Is there some other part that is likely to also need replaced?
Ads By Google
Related Models
Maytag CHE9830BCE Range - S/c S/i Ele
Admiral CHEA700BCB Range - S/c S/i Ele
Admiral CHEA700BCE Range - S/c S/i Ele
Whirlpool CHF7A1
Whirlpool CHF7W1
Maytag CHG9800AAB Range - S/c S/i Gas
Maytag CHG9800AAE Range - S/c S/i Gas
Maytag CHG9800BAB Range - S/c S/i Gas
Maytag CHG9800BAE Range - S/c S/i Gas
Maytag CHG9800BAM Range - S/c S/i Gas
Maytag CHG9830BAB Range - S/c S/i Gas
Maytag CHG9830BAE Range - S/c S/i Gas
Admiral CHGA400BAB Range - S/c S/i Gas
Admiral CHGA400BAE Range - S/c S/i Gas
Whirlpool CHS12RC
Whirlpool CHS12RC1
Whirlpool CHS5A
Whirlpool CHS5A2
Whirlpool CHS5R
Whirlpool CHS5W
Whirlpool CHS5W2
Whirlpool CHS7RC
Whirlpool CHS7RS
Whirlpool CHTS4AECP
Whirlpool CHTS4WECP
Whirlpool CHTS6AECP
Whirlpool CHTS6WECP
Amana CI7.7 Freezer - Chest
Amana CI8.8 Freezer - Chest
Amana CI8.8-C Freezer - Chest
Amana CIC-3 Ref - Top Mount
Amana CIC-4H Ref - Top Mount
Amana CIC3 Misc / Accessory
Amana CIC4 Misc / Accessory
Amana CIC4H Misc / Accessory
Amana CIC4K Misc / Accessory
Maytag CIKHTM-1  Misc / Accessory
Maytag CIKHTM-1V  Misc / Accessory
Amana CIM105 Ref - Bottom Mounts
Amana CIM105L Ref - Bottom Mounts
Amana CIM125 Ref - Bottom Mounts
Amana CIM125L Ref - Bottom Mounts
Amana CIM98 Ref - Bottom Mounts
Amana CIM98L Ref - Bottom Mounts
Amana CIMR-19 Ref - SXS/I&W
Amana CIMR-22 Ref - SXS/I&W
Amana CIMR14 Misc / Accessory
Amana CIMR14L Misc / Accessory
Amana CIMS14 Misc / Accessory
Amana CIMS14L Misc / Accessory
Hardwick CJ1616A49R Range - F/s Std Gas
Hardwick CJ1616W49R Range - F/s Std Gas
Hardwick CJ1626A49R Range - F/s Std Gas
Hardwick CJ1626W49R Range - F/s Std Gas
Thermador CJ302UB
Thermador CJ302US
Thermador CJ302UW
Thermador CJ302ZS
Hardwick CJ7121809RC Walloven - Std Gas
Hardwick CJ7122809RC Walloven - Std Gas
Hardwick CJ7141809RC Walloven - Std Gas
Hardwick CJ7141819DE Walloven - Std Gas
Hardwick CJ7142809RC Walloven - Std Gas
Hardwick CJ9641A590R Range - F/s Std Gas
Hardwick CJ9641W590R Range - F/s Std Gas
Amana CJW1008.A Commercial Microwaves
Amana CJW1008.B Commercial Microwaves
Amana CJW1008.Z Commercial Microwaves
Amana CJW1040.A Commercial Microwaves
Amana CJW1040.B Commercial Microwaves
Amana CJW1040.Z Commercial Microwaves
Gaggenau CK062-604
Gaggenau CK064-604
Gaggenau CK066-604
Gaggenau CK067-604
Gaggenau CK069-604
Gaggenau CK074-604
Gaggenau CK074-614
Gaggenau CK074-624
Gaggenau CK163-604
Gaggenau CK169-604
Gaggenau CK260-604
Gaggenau CK270-604
Maytag CK277SS-1  Misc / Accessory
Maytag CK277SS-1V  Misc / Accessory
Gaggenau CK390-615
Gaggenau CK394-615
Gaggenau CK396-615
Gaggenau CK590-615
Gaggenau CK596-615
Hardwick CKD7121810AC Walloven - Cont Clean Gas
Hardwick CKD7122810AC Walloven - Std Gas
Hardwick CKD7221819A Walloven - Cont Clean Gas
Hardwick CKD7221819AC Walloven - Std Gas
Hardwick CKD7222810AC Walloven - Std Gas
Hardwick CKD7222819A Walloven - Std Gas
Hardwick CKD7224810AC Walloven - Std Gas
Hardwick CKD7224819A Walloven - Std Gas
Hardwick CKD7241819A Walloven - Cont Clean Gas
Hardwick CKD7242819A Walloven - Std Gas
Hardwick CKD7244819A Walloven - Std Gas
Hardwick CKD9512W439R Range - F/s Cont Clean Gas
Hardwick CKD9512Y439R Range - F/s Cont Clean Gas
Hardwick CKD9516W421R Range - F/s Cont Clean Gas
Hardwick CKD9517W429R Range - F/s Cont Clean Gas
Hardwick CKD9521A439R Range - F/s Cont Clean Gas
Hardwick CKD9521W439R Range - F/s Cont Clean Gas
Hardwick CKD9521W79R Range - F/s Std Gas
Hardwick CKG4612MA539RG Range - F/s Cont Clean Gas
Hardwick CKG4612MW539RG Range - F/s Cont Clean Gas
Hardwick CKG4642MA639RG Range - F/s Cont Clean Gas
Hardwick CKG4642MW639RG Range - F/s Cont Clean Gas
Hardwick CKG8421MA729RG Walloven - Std Dbl Oven Gas
Hardwick CKG8421MW729RG Walloven - Std Dbl Oven Gas
Hardwick CKG9622W439RGB Range - F/s Cont Clean Gas
Hardwick CKG9641W589RGC Range - F/s Cont Clean Gas
Hardwick CKJ9641A580RW Range - F/s Cont Clean Gas
  #2 (permalink)
Old 01-27-2009, 01:43 PM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
it sounds like you have it wired correctly. the switch is what tells the burner what to do. i would replace the switch. tom ******************************************** - parts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burner stays on high setting. billheider Oven Repair (including Ranges and Cooktops) 0 01-26-2010 09:25 AM
Dryer stays on high setting Macman1107 Dryer Repair 0 01-07-2010 05:48 PM
Ge Burner On High No Matter What The Setting Is On FDAR Oven Repair (including Ranges and Cooktops) 2 10-22-2009 06:37 AM
operates on low temp setting only dryskamp Dryer Repair 4 11-30-2008 08:58 AM
High temp. setting too hot RPS Dryer Repair 2 12-22-2007 01:48 AM
