Discuss
Old Caloric broiler & Hinge repair
 in
I have an old 1970's Caloric L-series self cleaning gas range with ultra ray broiler. Model # RSL399-N3, Serial #
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Old Caloric broiler & Hinge repair
  #1 (permalink)
Old 01-27-2009, 03:45 AM
Junior Member
duoduo is on a distinguished road
Default Old Caloric broiler & Hinge repair
Model Number: RSL399-N3   Brand: Caloric   Age: More than 10 years
I have an old 1970's Caloric L-series self cleaning gas range with ultra ray broiler. Model # RSL399-N3, Serial # 2395196. It is a high/low setup, with a smaller oven above.
Recently the broiler in the bottom oven stopped working. The standing pilots for the broiler and the oven are on. The oven works but the broiler does not. What could be wrong? Is there something I can check or do to fix this? Can I install the part myself? (Picture attached. I can provide more if needed.)
Also the hinges have not been working properly for awhile. I think the springs need to be replaced. One of the hinges broke when the door fell down one time, this could be welded probably. How do I go about taking out the hinges to examine them? (Picture attached) It looks like two screws hold a small plate which sits over a larger plate held by two more screws. Do I remove all four or just the two on the smaller plate? Is there a part number for the springs? I think the hinges are obsolete.
Related Models
Amana RSL459P MWAVE- CNTRTP / STAND ALONE
Amana RSL659P MWAVE- CNTRTP / STAND ALONE
Amana RSL669T MWAVE- CNTRTP / STAND ALONE
Amana RSS307 RANGE- S/C S/I DDRAFT GAS
Amana RSS307-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS343 RANGE- S/C S/I DDRAFT GAS
Amana RSS352 RANGE- S/C S/I DDRAFT GAS
Amana RSS352-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS353 RANGE- S/C S/I DDRAFT GAS
Amana RSS353-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS354 RANGE- S/C S/I DDRAFT GAS
Amana RSS354-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS356UL RANGE- S/C S/I DDRAFT GAS
Amana RSS356UL,W RANGE- S/C S/I DDRAFT GAS
Amana RSS356UW RANGE- S/C S/I DDRAFT GAS
Amana RSS358UL RANGE- S/C S/I DDRAFT GAS
Amana RSS358UL,W RANGE- S/C S/I DDRAFT GAS
Amana RSS358ULCO RANGE- S/C S/I DDRAFT GAS
Amana RSS358ULG RANGE- S/C S/I DDRAFT GAS
Amana RSS358ULGCO RANGE- S/C S/I DDRAFT GAS
Amana RSS358UW RANGE- S/C S/I DDRAFT GAS
Amana RSS358UWCO RANGE- S/C S/I DDRAFT GAS
Amana RSS358UWG RANGE- S/C S/I DDRAFT GAS
Amana RSS358UWGCO RANGE- S/C S/I DDRAFT GAS
Amana RSS359 RANGE- S/C S/I DDRAFT GAS
Amana RSS359-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS361 RANGE- S/C S/I DDRAFT GAS
Amana RSS361-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS363 RANGE- S/C S/I DDRAFT GAS
Amana RSS363-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS369 RANGE- S/C S/I DDRAFT GAS
Amana RSS369-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS380 RANGE- S/C S/I DDRAFT GAS
Amana RSS380-OF RANGE- S/C S/I DDRAFT GAS
Amana RSS398 RANGE- S/C S/I DDRAFT GAS
Amana RSS399 RANGE- S/C S/I DDRAFT GAS
Maytag RST2200EAE REF - SXS/I&W
Maytag RST2200EAM REF - SXS/I&W
Maytag RST2200FAE REF - SXS/I&W
Maytag RST2200FAM REF - SXS/I&W
Maytag RST2400EAE REF - SXS/I&W
Maytag RST2400EAM REF - SXS/I&W
Maytag RST2400FAE REF - SXS/I&W
Maytag RST2400FAM REF - SXS/I&W
Amana RST307 RANGE- S/C S/I DDRAFT GAS
Amana RST307/ALL RANGE- S/C S/I DDRAFT GAS
Amana RST3079310 RANGE- S/C S/I DDRAFT GAS
Amana RST307F043 RANGE- S/C S/I DDRAFT GAS
Amana RST307UWW RANGE- S/C S/I DDRAFT GAS
Amana RST308U RANGE- S/C S/I DDRAFT GAS
Amana RST308UK RANGE- S/C S/I DDRAFT GAS
Amana RST308UL RANGE- S/C S/I DDRAFT GAS
Amana RST308UW RANGE- S/C S/I DDRAFT GAS
Amana RST308UWW RANGE- S/C S/I DDRAFT GAS
Amana RST309 RANGE- S/C S/I DDRAFT GAS
Amana RST309/ALL RANGE- S/C S/I DDRAFT GAS
 RST310UK RANGE- S/C S/I GAS
 RST310UL RANGE- S/C S/I GAS
 RST310UW RANGE- S/C S/I GAS
 RST310UWW RANGE- S/C S/I GAS
Amana RST354 RANGE- S/C S/I DDRAFT GAS
Amana RST354/ALL RANGE- S/C S/I DDRAFT GAS
Amana RST359 RANGE- S/C S/I DDRAFT GAS
Amana RST359/ALL RANGE- S/C S/I DDRAFT GAS
Amana RST361 RANGE- S/C S/I DDRAFT GAS
Amana RST361/ALL RANGE- S/C S/I DDRAFT GAS
Amana RST362 RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 02-05-2009, 11:03 AM
Junior Member
Default Caloric Broiler - Gas Oven Safety
I had my Caloric (Model # RSL399-N3) broiler checked out by my utility company and they told me the problem was the "gas oven safety" for the broiler. They did not stock these parts.
Can anyone tell me if that part is still available and if so a part # or place to purchase one. Is this part something that could be repaired if it is not available? How would I go about removing it?
Thanks for your help.
  #3 (permalink)
Old 02-16-2009, 03:33 PM
Junior Member
Default Caloric Broiler - gas safety valve
I think I found the correct part to replace my gas oven safety valve.
Now I'm trying to figure out where it goes. The broiler pilot light in my bottom oven is at the top. Is the valve underneath the cooktop panel?
Is anyone familiar with these older stoves?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Caloric Oven and Broiler Igniter do not turn on. DBuckman Oven Repair (including Ranges and Cooktops) 3 01-23-2012 05:28 PM
oven door hinge repair jemarevans Oven Repair (including Ranges and Cooktops) 0 12-29-2009 01:34 PM
Caloric Oven hinge replacement firemante Oven Repair (including Ranges and Cooktops) 2 04-22-2009 06:06 PM
Repair of top over door hinge akd123 Oven Repair (including Ranges and Cooktops) 3 05-14-2008 06:18 PM
frigidaire oven hinge repair rshuck50 Oven Repair (including Ranges and Cooktops) 0 01-26-2008 07:54 AM
