| » cleaning glaa in oven door |
Model Number: KEB5207DBL9 Brand: Kitchen Aid Age: 5 - 10 years
how to remove oven door to clean glass
Charles,
We're not sure how far you'll need to go, but here's the information you requested, REMOVE OVEN DOOR IMPORTANT: Use both hands to remove oven door. 1. Open the oven door. 2. Locate the oven door latches in both corners of the oven door, and rotate the latches forward to the unlocked position. 3. Grasp the edges of the oven door with both hands and close the oven door until it will no longer close. Lift and pull oven door toward you and remove. Set the oven door aside on a covered work surface. REMOVING OVEN DOOR GLASS AND HANDLE 1. Open the oven door. 2. Raise the two door hinge tabs to the “unlocked” position. 3. Close the oven door to within several inches, lift and pull out on the hinges, and remove them from the oven slots. 4. Place the oven door front side down on a padded surface to protect the finish. 5. Remove the two screws from each of the bottom corner glass holders and remove the holders. 6. To remove the inner oven door glass panels, lift each of the three glass panels, and remove them from the door. 7. To remove the door handle and outer oven door glass: a) Remove the three inner glass panels . b) Remove the three screws from the air vent and remove the vent. c) Remove the four door handle bracket screws and remove the brackets and handle from the door. d) Slide the bottom edge of the outer oven door glass out of the door frame and remove the glass. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| how to open the oven door after self cleaning ? | pmann | Oven Repair (including Ranges and Cooktops) | 6 | 11-05-2010 09:38 AM |
| door won't latch for oven self cleaning | richard courtois | Oven Repair (including Ranges and Cooktops) | 0 | 02-14-2010 05:58 PM |
| can't lock oven door for self cleaning | grambo | Oven Repair (including Ranges and Cooktops) | 7 | 09-10-2009 09:44 AM |
| oven door cleaning | Belle2 | Oven Repair (including Ranges and Cooktops) | 1 | 08-31-2009 04:08 PM |
| can't lock oven door for self cleaning | grambo | Oven Repair (including Ranges and Cooktops) | 1 | 04-04-2008 03:37 PM |
