Originally Posted by: OVENNOTWORKING Oven Takes Long Time To Get Hot..when I Turn The Oven On It Has To Be On The Broiler First Then The Oven Get Hot...that Lasted For A Couple Of Days ..now I Turn On The Oven Nothing..when I Turn On The Broiler The Bulb Just Glow (dim Glow). Ovennotworking, Normally, I would think you'd need the bake burner igniter Part number: AP4012072
Based on the initial post, but I also have to wander if you also have a bad Thermostat, Part number: AP4092858
Are you sure the igniter does not come on at all, unless you select the Broil setting ? If you have a multimeter, you need to check for 120 VAC on the wires going to the igniter, from the thermostat on both settings, we'd have a better idea. Hopefully it's not both. Good Luck, :) :) :)
