I have a kenmore oven that works sporadically. Broil works fine, as do the top burners. When the oven is not working, I have, at times, smelled a hint of gas. When it is working, it sometimes takes forever to reach temperature. Any help would be appreciated.
Most likely the problem is a bad Bake igniter. The model number you posted does not come up. Verify and repost it.
replace the ignitor. it is not strong enough to open the gas valve fully. tom [url=]applianceeducator.com - parts[/url]
