I have a Kenmore Elite convection oven and the turn table is not working. thanks for any help
Originally Posted by: racerx8803 I have a Kenmore Elite convection oven and the turn table is not working. thanks for any help RacerX, You'd want to remove the lower panel, disconnect the harness to the cooktop lights and turntable motor. You need to unplug the power cord first. With a multi meter, Part number: AP3873826
you'd need to check for 120 VAC across the 2 wires to the motor, once you program a cook mode, No voltage would indicate a bad smart board or broken / loose wire. With voltage present, you'd have a bad turntable motor. Part number: AP3183636
Good Luck, :) :) :)
