| » Oven Error Codes |
LinkBack (6) | Thread Tools | Search this Thread | Display Modes |
I had the same problem with the same oven. The solution was to provide some insulation in the control wires. The procedure was developed by Charlie Popeck and is described at
The Dreaded "F7" Error - FixYa |
are model number is fgfl67dbd, it is a gas range oven. it goes into the f10 mode all the time. while we are trying to use the oven to cook.what do i need to do to fix this problem. any help would be greatly appreciated.
eyecu1965dad,
"F10" error code means runaway temperature. Check resistance of the oven temperature probe (aka temperature sensor). Normally it suppose to be about 1100 Ohms at the room temperature. If the reading is wrong then replace the sensor. If the reading is correct then replace the Electronic Oven Control (EOC). - The part number for the oven temperature sensor is AP3704441 - The part number for the EOC is AP3778770 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
mabeck52,
What is the complete model number of the range? Gene.
__________________
Range, Maytag; MN CRE9600CCE;
Just replaced bottom oven element. It works fine, but will not turn off. Oven overheats and I am getting a F2 code and then an F7 code. Cancel button or oven stop button will not turn oven element off. Must unplug to turn off. Clock and other buttons as well as temp display seem to work OK. Oven stop button does turn temp display off. HELP Last edited by eastex : Yesterday at 09:36 PM. |
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
| Posted By | For | Type | Date |
| Digg - Who dugg or blogged: Oven Error Codes | This thread | Refback | 01-01-2008 02:57 PM |
| Digg - Oven Error Codes | This thread | Refback | 12-06-2007 08:29 PM |
| Digg - Oven Error Codes | This thread | Refback | 10-15-2007 08:21 PM |
| digg / postaholic / news / submitted | This thread | Refback | 08-15-2007 10:11 PM |
| Digg - Oven Error Codes | This thread | Refback | 08-01-2007 03:15 PM |
| Digg / News / Upcoming | This thread | Refback | 08-01-2007 03:10 PM |
| Display Modes | |
| Oven oesn't bake/heat and displays a "FS" error message | jnymdnyt | Oven Repair (including Ranges and Cooktops) | 5 | 08-06-2007 07:36 PM |
