| » Oven Error Codes |
LinkBack (6) | Thread Tools | Search this Thread | Display Modes |
w2002s,
Check if there is 120VAC between the red wire (R-1 on the wiring diagram) at the control board and ground. If the reading is wrong then one of two 120VAC legs to the oven is missing. It could be the circuit breaker or a broken wire. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
w2002s,
There is proper power to everything in the oven, according to your reports. You just replaced the EOC. The oven is still not working with unknown error code -1- which I never heard for all my life. Double check all electrical connections and components and if there is nothing wrong, call a certified technician. Gene.
__________________
my crosley gas range wouldn't come up to temp. I replaced the complete clock/relay and things worked fine. Now working for 3 months and an F1 error code comes on approx once a day and beeps? In the middle of the night when the oven is non operational. Can anyone help?
Hi Monk,
What is the complete model number of the range? Gene.
__________________
Hi Monk,
Most likely the problem is a bad touch pad. - The part number for the control panel is AP304866 Here are the break down diagrams for the Crosley range Model CG3478XRW Gene.
__________________
The "F2" error code means "temperature runaway detected by the control".
For which oven, upper or lower, the error code was shown? In which mode: time of the day, cooking or self cleaning the error code was shown? Gene.
__________________
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
| Posted By | For | Type | Date |
| Digg - Who dugg or blogged: Oven Error Codes | This thread | Refback | 01-01-2008 02:57 PM |
| Digg - Oven Error Codes | This thread | Refback | 12-06-2007 08:29 PM |
| Digg - Oven Error Codes | This thread | Refback | 10-15-2007 08:21 PM |
| digg / postaholic / news / submitted | This thread | Refback | 08-15-2007 10:11 PM |
| Digg - Oven Error Codes | This thread | Refback | 08-01-2007 03:15 PM |
| Digg / News / Upcoming | This thread | Refback | 08-01-2007 03:10 PM |
| Display Modes | |
| Oven oesn't bake/heat and displays a "FS" error message | jnymdnyt | Oven Repair (including Ranges and Cooktops) | 5 | 08-06-2007 07:36 PM |
