Discuss
Oven Error Codes
 in
Good luck with a new one and Happy Holidays. Gene.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  #61 (permalink)
Old 11-29-2008, 09:37 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
__________________
  #62 (permalink)
Old 12-13-2008, 02:45 PM
TempletonPeck TempletonPeck is offline
Junior Member
TempletonPeck is on a distinguished road
Default
Frigidaire CGLEF385AS1
F3 error code.
Looking for some help on diagrams, parts, what to do please.
  #63 (permalink)
Old 12-13-2008, 08:30 PM
Cyntharian Cyntharian is offline
Junior Member
Cyntharian is on a distinguished road
Default F10 Error code
I have a electric Tappan Range. It's model number is TEF326FBB
The burners work, but if you press the bake button the oven just starts beeping. Tried turning off and on the electricity to it but it just keeps doing it. When it first started this beeping, it only done it after we had finished cooking in the oven. Now we can't cook in it at all. It's only been beeping at us a few days. Help! Thanks.
  #64 (permalink)
Old 12-14-2008, 06:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
TempletonPeck,
"F3" error code means "open/shorted oven temperature sensor". The model number you posted does not come up. Verify and repost is.
__________________
  #65 (permalink)
Old 12-14-2008, 06:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Cyntharian,
"F10" error code means "Runaway temperature". If it appears at start of cooking then the problem, most likely, is a bad control board (aka a clock). You also have to replace the overlay.
- The part number for the clock is AP3956392
- The part number for the black overlay is AP2126494
Here are the break down diagrams for the Tappan range Model TEF326FBA
__________________
  #66 (permalink)
Old 12-16-2008, 04:09 PM
coolambo coolambo is offline
Junior Member
coolambo is on a distinguished road
Default Whirpool RB262PXA - F5 error code
Hello APPros! New member here. Can you please help me? My built-in oven Whirpool RB262PXA is giving an F5 error. When I turn BAKE on, I set the temp to 350. It powers on for about 30 seconds and shuts off for the F5 error.
I called Whirpool and advised me to turn off the breaker for the over or unplug it then power up and turn the over back on. I was advised I may have a bad circuit board???
Now in your website I came across 1 person potentially having the same problem and the part number for his board (which is most likely similar to mine) is AP38295.
Am I in the right track here? Oh one problem I've noticed is this board is no longer available for sale. What do I do next?? Please help. Thanks!!!
  #67 (permalink)
Old 12-16-2008, 07:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the door latch switch (#19 on th break down diagram) for continuity in both position. If there is nothing wrong then the control board is bad and has to be replaced. This part has been discontinued and is no longer available but you can try the company which does rebuild old control boards.
Here are the break down diagrams for the Whirlpool oven Model RB262PXAB0
__________________
  #68 (permalink)
Old 12-22-2008, 02:25 PM
Servicer Servicer is offline
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
Here are the Thermador ESC/GSC error codes.
  #69 (permalink)
Old 01-03-2009, 10:04 AM
samxp samxp is offline
Junior Member
samxp is on a distinguished road
Default
Quote:
Originally Posted by Gene View Post
Cyntharian,
Wow, thanks for that break down diagram! I just tested the RTD in my Tappan TEF326FBA and it showed 1080 milliohms at room temp, so I'm guessing it is fine, but I have a runaway temperature condition. Problem is, no error codes display. Do you have to press some buttons (or a combination of buttons) to display the error codes?
I'm guessing the clock and overlay need to replaced and that's pretty much what I'd pay for a new one, so I was hoping it was just the RTD.
Thanks!
  #70 (permalink)
Old 01-06-2009, 07:44 AM
closs2sx closs2sx is offline
Junior Member
closs2sx is on a distinguished road
Default help kenmore 66595002100 electric range with "pf" code
also the top element in the oven will not shut off at all
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
