Discuss
Oven Error Codes
 in
I had the same problem with the same oven. The solution was to provide some insulation in the control wires.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Error Codes
LinkBack (6) Thread Tools Search this Thread Display Modes
  #51 (permalink)
Old 08-29-2008, 07:31 AM
arnieg arnieg is offline
Junior Member
arnieg is on a distinguished road
Default
I had the same problem with the same oven. The solution was to provide some insulation in the control wires. The procedure was developed by Charlie Popeck and is described at
The Dreaded "F7" Error - FixYa
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #52 (permalink)
Old 10-05-2008, 07:47 PM
eyecu1965dad eyecu1965dad is offline
Junior Member
eyecu1965dad is on a distinguished road
Angry frustrated customer
Quote:
Originally Posted by Gene View Post
Hi SMIMS,
In order to provide most accurate advise I need the complete model number of the range.
are model number is fgfl67dbd, it is a gas range oven. it goes into the f10 mode all the time. while we are trying to use the oven to cook.what do i need to do to fix this problem. any help would be greatly appreciated.
  #53 (permalink)
Old 10-06-2008, 06:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
eyecu1965dad,
"F10" error code means runaway temperature. Check resistance of the oven temperature probe (aka temperature sensor). Normally it suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong then replace the sensor.
If the reading is correct then replace the Electronic Oven Control (EOC).
- The part number for the oven temperature sensor is AP3704441
- The part number for the EOC is AP3778770
__________________
Professional appliance repair in Los Angeles, California.
  #54 (permalink)
Old 11-06-2008, 09:16 AM
mabeck52 mabeck52 is offline
Junior Member
mabeck52 is on a distinguished road
Default Tappan Error Code
I have a Tappan range, error code F10 (not on the list). What does this mean? Easy to fix? Costly?
  #55 (permalink)
Old 11-06-2008, 12:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
mabeck52,
What is the complete model number of the range?
__________________
  #56 (permalink)
Old Yesterday, 07:43 PM
eastex eastex is offline
Junior Member
eastex is on a distinguished road
Question
Range, Maytag; MN CRE9600CCE;
Just replaced bottom oven element. It works fine, but will not turn off. Oven overheats and I am getting a F2 code and then an F7 code. Cancel button or oven stop button will not turn oven element off. Must unplug to turn off. Clock and other buttons as well as temp display seem to work OK. Oven stop button does turn temp display off.
HELP
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/219-oven-error-codes.html
Posted By For Type Date
Digg - Who dugg or blogged: Oven Error Codes This thread Refback 01-01-2008 02:57 PM
Digg - Oven Error Codes This thread Refback 12-06-2007 08:29 PM
Digg - Oven Error Codes This thread Refback 10-15-2007 08:21 PM
digg / postaholic / news / submitted This thread Refback 08-15-2007 10:11 PM
Digg - Oven Error Codes This thread Refback 08-01-2007 03:15 PM
Digg / News / Upcoming This thread Refback 08-01-2007 03:10 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven oesn't bake/heat and displays a "FS" error message jnymdnyt Oven Repair (including Ranges and Cooktops) 5 08-06-2007 07:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
